Sponsored by: Real Truck
Direct HOT Connect
Old Jan 12, 2009 | 10:56 PM
DAVE67FD's Avatar
DAVE67FD
First i would take the cig lighter and make sure it is up to par. remove the fuse and spring, clean all the contacts (and the fuse) with a fine wire brush and wipe with contact cleaner or alcohol. extend the spring slightly and re-install it thouroughly and make sure the end is tight. If it has the spring style side ground clips you can pull them out slightly. Take a cotton rag with the cleaner and place on the end of a non conductive tool (a small wooden dowel works well) and gently clean the inside of the lighter plug socket. Keep your Ryobi charger in-tact you might find that you may want to move it to another vehicle at some point.
omni
Electrical Systems/Wiring
Nov 18, 2014 05:28 PM
berick
Feb 15, 2014 06:28 PM
ac700wildcat
Garage & Workshop
Jul 23, 2010 07:11 PM
blighty
Jan 5, 2008 08:10 PM
ford_nut
All Things Towing
Jan 8, 2003 08:30 AM
