I have a K&N Air Filter on my 390 in my '66 F100.
It measures 3-1/8" High / 14" Diameter actual size.
(i believe this was considered the 4" though)
I actually tried the one from my '67 Chevelle and it worked perfect, so I knew what size would work. I got mine from Checker Auto. They were they only ones in my area to have that one. (sorry I don't have a part #)
~Bob
How much is your time worth at this point. You can buy an aftermarket chrome cleaner for $30-40. Don't know how much you make an hour, but if you've gone to that many places you have wasted a lot of time. If you are going for the 100% original thing I can understand. If not then do the math.
Based on what Number Dummy said about all big blocks using an FA50 air cleaner I went out and looked at my two big block air cleaners. The original on my 67 410 and then in my spare 67 390 cleaner. They were both the same a Fram CA133 which is about 9 7/8" OD, 7 1/2 ID and just over 2 1/4 tall. A 13" OD air filter wouldn't even fit the provided platform in the cleaner assembly for that size filter. It would fall right off.
Based on what Number Dummy said about all big blocks using an FA50 air cleaner (I didn't say all, I said 1968/72), I went out and looked at my two big block air cleaners. The original on my 67 410 and then in my spare 67 390 cleaner. They were both the same a Fram CA133 which is about 9 7/8" OD, 7 1/2 ID and just over 2 1/4 tall. A 13" OD air filter wouldn't even fit the provided platform in the cleaner assembly for that size filter. It would fall right off.
OP's air cleaner element approximate dimensions: 13.00" O.D. / 11.50" I.D.
FA50: 13.30" O.D. / 11.32" I.D. This is only element that comes close to matching the criteria.
This element fits 1968/72 F100/350's w/302/360/390's // 1968/72 cars w/302/390/428/429/460's.
It does not fit 1967 anything, and I never said it did. See posts #5 & #10.
1967
