explorer 4wd solenoid
There is no relation between 4wd operation and vacuum on your '92 ('95 and '96 Explorers used a vaccum system to operate the front axle disconnect).
Usually when the system doesn't respond to the buttons, there's a problem with the shift motor (dirty/sticky and it won't turn or similar). Sometimes tapping the shifting motor with something will free it up. There are a couple of places on the net that describe how to take it apart and clean it up, too (therangerstation.com and explorerforum.com).
As for a manual bypass, it's not very convenient, but you can take the shift motor off and rotate the shaft by hand using a pair of vise grips or similar.
As common as the shift motor is, I'd start there. If that isn't the problem, then I'd look at the switches and the electrical connections (my '92 wouldn't shift one day, so I jiggled the connector and the shift module and the system worked just fine, I guess there was a bad connection right there).
JClarkHarris
10-19-2015 12:55 PM
ohgeewiz
12-26-2010 07:33 PM
confer1
01-26-2009 06:50 PM
