4wd Control Module
Old Sep 17, 2008 | 01:50 PM
ctboyle03's Avatar
ctboyle03
4wd Control Module
Anyone know where to get a 4wd control module on the interweb? New or used doesn't matter as long as it works. I have a 2001 Mazda B4000 and I have narrowed down my problem to the module. Links would be very much appreciated! Thanks, Chris
Old Sep 17, 2008 | 06:24 PM
Bear River's Avatar
Bear River
Former ******
Ok, what is your problem? What module are you referring to?
Old Sep 18, 2008 | 06:45 AM
ctboyle03's Avatar
ctboyle03
I'm getting nothing when I turn the switch into 4 high and 4 low - no indicator light, no click. I replaced the motor on the transfer case and replaced the switch (used parts from the local pull-your-own parts place) and still nothing. All the fuses are OK so i figure i'll try the control module next. The Ranger that i pulled the transfer case motor from was already missing its 4wd control module so i guess someone beat me to it. It's the module down behind the passenger side kick panel.
Old Sep 19, 2008 | 12:25 PM
ctboyle03's Avatar
ctboyle03
went back to the pull-your-own parts place today and grabbed the control module off a ranger for $11. Model numbers were a bit different, but it was from a newer Ranger so I figured they'd be different. I swapped out the control modules when i got home and everything is up and running again. I opened up the case on the old one and don't see any visible signs of damage so i'm not sure what happened to it, guess it just felt like not working anymore.
I also grabbed a 4wd control module off a 2003 Explorer in case the one from the Ranger didn't work. So if anyone has any use for it, let me know and we can make arrangements. part # 2C54-7H473-BF Model# 2MU152ND06
Outbreaker
Jul 9, 2015 03:04 PM
Outbreaker
Jun 27, 2015 10:20 AM
AZRRC
Arizona Chapter
Sep 12, 2014 12:01 PM
chris9n
Nov 20, 2007 10:02 AM
ChrisAdams
2004 - 2008 F150
15
Mar 6, 2005 11:58 PM
