1978 - 1996 Big Bronco
Bronco Frame Welding
Old Jan 10, 2009 | 07:10 PM
AlChalmers10's Avatar
AlChalmers10
Hello,
I need to do some welding on the frame of my 85 Bronco. Does anyone know if the frame is high tensile steel, or is it mild steel? What type of welding rod should I use in my stick welder? Any info would be appreciated. Thanks. Al.
Old Jan 10, 2009 | 08:03 PM
grizzly54's Avatar
grizzly54
I would use 7018 if it was me.
Old Jan 10, 2009 | 09:47 PM
drunkdave's Avatar
drunkdave
As far as I know its mild. You could run 7018, just make sure you prep it real good. If you cant fit a grinder in the area, you could run 6011. Just clean the area up with a wire brush and get all the loose rust and all the paint off if you can.
Old Jan 11, 2009 | 06:08 PM
grizzly54's Avatar
grizzly54
6010 or 6011 would be ok for your root pass to clean up the metal if it is dirty but then I would use 7018 for all the other passes.
Old Jan 11, 2009 | 10:45 PM
helirich's Avatar
helirich
I have heard that all frames are heat treated and shouldnt be welded. That said, I have welded frames many times. (of course that doesnt make it right) If it's got a crack, what else are you going to do? But if its not cracked, you might try bolts for whatever your doing.
Old Jan 12, 2009 | 02:11 AM
greystreak92's Avatar
greystreak92
Holes and hardware will always triumph over hot glue (even if it is hot glue with a serious attitude)!
Old Jan 24, 2009 | 06:52 PM
justshootme84's Avatar
justshootme84
I find it much easier to use a 1/8" 6011 than a 7018 when welding on the Bronco frame, especially anything overhead. While alot of the suspension brackets are bolted up on the 84 Bronco, I often tack weld the bracket in a couple places. I'm running a Dana60 leaf SAS up front with a rear shackle flip Sterling 10.25". have also boxed the frame in a few places up front and where the rollcage outriggers tie in, using 1/8" mild steel. The Bronco frame works and acts similar to the mild steel when welding it ,if that helps any? JSM84
Aaron-71
Aug 20, 2015 09:42 PM
mjpower76
Apr 22, 2014 12:46 PM
fordracer08
Jul 21, 2012 09:49 AM
Caveman2851
18
May 2, 2011 08:38 PM
ol74hb
24
Apr 2, 2003 10:02 PM
