Engine Codes and injector trouble
Old Feb 13, 2009 | 03:45 PM
F350-6's Avatar
F350-6
Originally Posted by rjmjr78
Don't know how to PM, hate to take up space on someone else's question, but not sure what to do.
Start your own thread and we can walk you through whatever issue you're having. You've got to have at least 25 posts before you can PM
Old Feb 13, 2009 | 04:30 PM
rjmjr78's Avatar
rjmjr78
This may make me sound like a dum-dum, but I don't know how.
Old Feb 13, 2009 | 04:36 PM
rjmjr78's Avatar
rjmjr78
This may make me sound like a dum-dum, but I don't know how, love all the info on the site but sometimes get myself lost. You won't happen to have an ae scan tool would you?
Old Feb 14, 2009 | 08:28 AM
F350-6's Avatar
F350-6
Yes I have an AE scan tool. Do you live near me?
Have you checked the wiring where it plugs into the valve cover gasket? How rough is your truck running, and how long have you noticed you might have a problem?
Old Feb 14, 2009 | 12:21 PM
rjmjr78's Avatar
rjmjr78
I'm in Hitchcock. Yes the valve wiring ohmed out good. It still drives ok, just idles rough, down on power, bad fuel mileage. It has been this way for a while, just been reading on this site and getting more comfortable with messing with it. Would like to get it hooked up to a scan tool to know whats going on.
Old Feb 14, 2009 | 12:30 PM
F350-6's Avatar
F350-6
I'm up near Hillsboro, but know someone who MIGHT be able to help you out with a scan. I'll send him a message.
Old Feb 14, 2009 | 12:46 PM
rjmjr78's Avatar
rjmjr78
Thanks, any help would be great.
Old Feb 14, 2009 | 03:03 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by F350-6
The loose connectors under the valve cover are a known issue with these trucks. International came out with a set of clips that can be installed to correct this problem. Members here started playing with different types of shims to use instead of buying the clips. It was discovered that a quarter (25 cent piece) happens to be the correct thickness and diameter (if one end is trimmed) to act as a shim. That's where the 25 cent mod comes from. Here's a link that shows what a loose connector looks like, and has pictures of the quarter shim https://www.ford-trucks.com/forums/8...ck-shakes.html
Chris is giving you the DIY info that was created when someone didn't use these clips.
UVC clips <~~clicky-clicky
Ford Part number: 2C3Z-14A163-AB
Some have found zip ties with the correct thickness work well too.
Stewart
cwbyup2002
Nov 20, 2014 09:39 PM
johnwassink
May 13, 2014 06:10 AM
majestek12
Dec 11, 2013 11:24 AM
MWJ1973
Nov 6, 2013 12:41 AM
tikicaptain
25
Jun 26, 2009 09:29 AM
