Lockout hubs
Old Jan 9, 2009 | 05:31 PM
ped222's Avatar
ped222
Lockout hubs
Hi
I'm new to the forum and I just bought an F250 4X4. When I put it into 4 wheel drive and the hubs are locked in there is a noise from the front end that sounds like a bird chirping. I suspect a bearing. My question is can I lock the hubs and drive the truck in two wheel drive? If I really need the 4 wheel drive at least I won't have to get out and lock the hubs. I'd only use it if I have to until I have a chance to take it apart and fix it. Will this hurt anything?
Thanks
Terry
Old Jan 9, 2009 | 06:49 PM
gweeds's Avatar
gweeds
Locked hubs + 4HI = four wheel drive
Unlocked hubs + 4HI = no four wheel drive, drive shaft spins from transfercase, turns axle but not the wheels.
Locked hubs + 2HI = no four wheel drive, wheels turn the axle which turns the drive shaft, but its disconnected at the transfer case.
Unlocked Hubs + 2HI = no four wheel drive. Neither the front axle nor the drive shaft turns.
Any of these combos are fine, btw...
Old Jan 10, 2009 | 05:23 AM
metmag52's Avatar
metmag52
Welcome to the site---you will be amazed at the knowledge here( not from me BTW).
I run my hubs locked in almost all winter-though my truck is not my daily driver-- (-I only unlock em when I am heading on the highway for a long run.)..makes it really easy to pull a Chevy out of the snow without getting out of the truck !!!
Gary
Old Jan 11, 2009 | 06:53 AM
ped222's Avatar
ped222
Thanks for the replies. I'm going to tear the front end apart tomorrow, the noise is getting worse. I just hope it's u-joints not the differential
Old Jan 11, 2009 | 08:22 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to the site. Sounds like fun, get a Haynes manual.
Tim
Old Jan 11, 2009 | 08:41 AM
ElwoodMurphy's Avatar
ElwoodMurphy
Mine churped until I ran for awhile with the hubs locked in. That is how the bearings get lubed. Before you tear it down run it several miles with the hubs locked in but not in 4WD.
Old Jan 11, 2009 | 10:20 AM
Conanski's Avatar
Conanski
The U-joints in the front axle were lubed for life from the factory, and surprisingly even on trucks this old it's common to find those still in there but completely dried out. That's where the squeaking and chirping and clunking and vibration and wobly steering comes from on these truck when the hubs are locked, from U-joints in various stages of self destruction. Changing them involves disassembling the front end, but it's doable with common hand tools and a big bench vise.. though a special wheel bearing nut removal tool is needed. The joints are pretty cheap.
Old Jan 11, 2009 | 01:57 PM
ped222's Avatar
ped222
I've been running it with the hubs locked and in 2 wheel drive, but the noise is still there along with a little front end wobble when I put it into 4 wheel drive. So I'm going to replace the u-joints on both sides and all 4 bearings and races. I still have to locate that spanner wrench though. I'll keep ya posted. Oh and by the way how do I know which front end I have as far as a Dana 44 or a 50/60?
Old Jan 11, 2009 | 03:36 PM
tjc transport's Avatar
tjc transport
i ain't rite
look at your locking hub, where it mounts to the spindle hub. if there is a little bit of the spindle hub visible behind the locking hub, it is a Dana 44 ifs.
if the locking hub is the same size as the spindle hub, it is a Dana 50 ifs.
here are two pictures so you can see what i am talking about. while the D44 has warn replacement hubs, the stock ford hubs are the same.
here is the D44 hub
http://i41.photobucket.com/albums/e2...ort/D44hub.jpg
and here is the D50 hub
http://i41.photobucket.com/albums/e2.../d50-60hub.jpg
Old Jan 11, 2009 | 09:28 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Sounds like a bad spindle bearing. I had both spindle bearings go out within a couple weeks of one another last winter. They started by only making noise while the front axle was under power, then they started making noise all the time.
Old Jan 12, 2009 | 01:23 PM
rostena's Avatar
rostena
I don't think theres anything wrong with running with the hubs locked.
I run mine all winter with them locked. I very rarley drive on the highway tho.
Old Jan 12, 2009 | 02:16 PM
1994 F250: 351, C6
Yeah, as long as you are not doing a lot of highway driving the only thing lost by running with your hubs in is gas mileage.
Old Jan 12, 2009 | 10:05 PM
ped222's Avatar
ped222
Well for now I replaced both outer u-joints. When the snow season lets up I'm going to replace both spindle bearings. I don't know if they need replaced or not, with the two new u-joints it's like a new truck. If they are bad it will probably wack the joints out again, but they're cheap so I'll replace them too if nescessary. Thanks for all your help.
ScosheOwn
Jan 10, 2014 02:05 PM
dpty22
Jan 25, 2013 01:04 AM
rburri
Oct 31, 2011 09:44 PM
dicaro
Dec 5, 2008 10:46 AM
goatsniffer
Offroad & 4x4
Nov 17, 2006 06:40 AM
