electrica problem HELP!!
Old Jan 9, 2009 | 01:14 AM
fuelinjected73's Avatar
fuelinjected73
Exclamation electrica problem HELP!!
just want to start with HAPPY NEWYEAR!! everyone.well im new to this site and well i need help with my project. i have a 1973 ford f100 that i converted over to fuel injection.i took the complete harnesss out and replaced it with a complete hardness out of a 1994 ford f150 5.0.well i hook up everything just how it was on the 94 .i made the 3 big rectangle cuts on the fire wall for the wires to go tru.but heres my problem when i turn on the switch it wont start nor does the fuel pump turn on.i check all the fuses under the hood and the fuses under the dash and they are good and got power.the lights work,blinkers brake lights. im using the switch bock that unbolts at the steering column of the 94.i will appreciate any hints or thoughts to solve my problem.i will try to post pics tomorrow
Old Jan 9, 2009 | 05:23 AM
JRS2's Avatar
JRS2
There is an inertia switch on a 94, did you bring that forward (or do you have one) ? I am going thru something like this, and electrical diagrams might be needed. Looks like in my case have a dead incoming line to fuse box for EEC relay (my light doesn't come on when key on - engine light) ..... not sure if it helps
Old Jan 9, 2009 | 09:24 PM
fuelinjected73
Yes I did thanks
Old Jan 10, 2009 | 01:15 AM
Prozon's Avatar
Prozon
EEC Relay or Fuel Pump Relay?
Old Jan 10, 2009 | 08:48 AM
BigBlueOx's Avatar
BigBlueOx
You say it won't start, but will it turn over? Did the donor truck have dual tanks?
Old Jan 10, 2009 | 11:21 PM
fuelinjected73
i checked the relays and they are good. it wont turn over and yes the donor truck had dual tanks.i hooked the gas tank switch and the starter is new so i dont know what to do. the donor was a runner,i drove it home before taking it apart
Old Jan 10, 2009 | 11:31 PM
Prozon's Avatar
Prozon
I think that taking it apart is where you went wrong.
Old Jan 10, 2009 | 11:34 PM
quicklook2's Avatar
quicklook2
did you remove the computer from the 94?
Old Jan 11, 2009 | 01:29 AM
fuelinjected73
well the truck owed money on tags and everything is off the 94
jakerweb
Jan 14, 2016 05:28 PM
stevenjf88
Jun 10, 2015 06:16 PM
94FordMan77
Electrical Systems/Wiring
Apr 7, 2014 02:47 PM
r0cker
Jan 9, 2014 03:34 PM
Dr. Monstaa
38
Oct 21, 2012 09:23 AM
