Which four? 5, 6, 7, 8? If so, I would highly recommand doing the RR kit.
#1,3,4,7! Even on 4 cyclinders this truck had plenty of power to plow haha. Now that I am back on conventional oil... I am thinking I am going to stay on it and do my oil changes every 3-4K. Maybe the advantage of running synthetic oil much longer is actually not good for these trucks. Maybe you are better off sticking with dino and changing it often?? Thoughts?
Speaking as a Ford Technician A rough run smoking situation can be absolutly the problem. and from what it sounds like, Your technician was putting a new fuel regulator. this is located on the secondary fuel filter canister under your hood. This was a known concern with 6.0L engines. This is also a cause and effect chain. The Fuel Regulator failed due to crappy fuel (there is not much you can do about that). and due to the fuel regulator going belly up it changes your fuel pressure out of specification for your fuel injectors. And becuase the fuel pressure is out of spec injectors start to fail. I would reccomend staying on good diesel where you can find it. you can do this by taking a sample at the pump and sticking with the pump that has the least cloudyest fuel. Also adding cetane booster every 3 or 4 tanks would help lots too.
So how often should I change the fuel regulator? The tech said to me that he has never seen 4 injectors go when there was no issue with fuel pressure. I know in the past he changed out the fuel regulator, but I don't see that he did that this time. How do you feel about leaving in synthetic oil for 6-8k miles? Instead of just running conventional 3-4K?
Fuel regulator should only have problems when it goes out so it shouldn't be messed with otherwise. Yeah i have seen maybe 2 injectors go just because of bad fuel. 4 is a little much. but 6.0L have been known to surprize us sometimes. if all fuel pressure testing was followed out and no problems found there is definatly a cause for the injectors going out. It sounds strange that 4 of them would just drop out of no where. the colsest concern i have herd to something like this is the FICM going out. the FICM is the control module for the injectors so when it goes you get all sorts of rough run symptoms. very capable of taking out 4 injectors if it isn't operating properly. but if your ford tech has done all the testing and diagnosis required of him then i would go with the injectors and ask why they went out. But as for your 6-8k question absolutly not. 5k is a little much actually if you ask me. 5k is for newwer vehicles as they get miles on them you need to get closer and closer to 3k. Now this is my personal feel on oil changes, (shhh don't tell) When a ford dealer sells you an oil change at 39 dollars or what ever the lowwest they charge may be they make pretty much no money and are on the boarder of losing money. so when people have the option of lifetime of free oil changes they definatly lose money. As a mechanic 3K solid all the time. why do you think they tell you 5K? so its less often for them to lose money. evil isn't it?
We believe Hot Shot's Secret is the remedy for the problem.
I have cut out a section of an article that we are working on for this blog which better defines what the real issue is and why Hot Shot's Secret is such and amazing go-to remedy for this engine.
"To increase the efficiency in modern diesel engines, manufacturers have increased the pressure at the tip of the injector. This increase provides for a better, more efficient burn with added power. Older injectors would put out 1,200 psi at the injector tip but the new diesel engines put out 26,200 psi at the tip. To achieve this increase in pressure the manufactures had tighten the tolerance inside the injector. This increased the friction and temperature. The higher temperatures have a burning effect on the engine oil. A layer of oxidized oil and additives form, slowing down the injector and eventually stopping it altogether."
Taken a step further...one would have to wonder if a lot of the other issues with the 6.0 don't tie back to the lubrication-injector failure dynamic? I was thinking about this the other day. What about the EGR issue that seems so prevalent? Could that be from an inefficent or malfunctioning fuel system? What about issues as far as the HPOP??? Or how about the turbo issues??? Could these all be related???
Our customers who are using the Blue Diamond product as well as Hot Shot's Secret on a regular basis have high mileage vehicles (some with 500K+) and are very pleased with the results. We hear words like "a quieter engine, no turbo lag, better fuel mileage, easy starts etc..."
The only claim we can make is that we know that the product corrects the stiction issue and this in turn helps the engine to run more efficiently. It was designed independently and tested by International for this purpose. It was given a thumbs up because of its effectiveness.
We hope to have the article online for everyone's viewing sometime in the next week.
So then what is the advantage of going synthetic at double the cost of conventional? You will never see the advantage of viscosity breakdown if you change it that often. I thought the only real advantage was that you could run it longer, and it didnt break down nearly as fast.
If it were me i'd go full synthetic every 3k. Oil is oil but it gets dirty the same way. it turns black because of carbon residue from combustion so there is no such thing as oil that stays cleaner for a longer period of time. synthetic definetly helps lubrication though. no addatives. my 2 cents.
Totally agree with frequent changes - I go 5k w/ synthetic and have no interest in extending that. Some folks seem to get by with longer intervals but IMO, when they do, it is with a fair potential for future problems.
Unfortunately the hot shots treatment did not help my truck.
Hi,
Thanks for the reply and update. We invite all feedback from our customers.
Again, this does happen.
Perhaps the condition of the injectors is beyond help. Perhaps another treatment is necessary to see improvement in performance. Sometimes they are so built-up with oxidation that one treatment is not enough to clean it.
However, if you are dissatisfied and see no results another electrical or mechanical problem may be to blame.
The product does come with a 100% guarantee. Please contact Chris at the office and he will be happy to get you a refund.
