Not A Problem, But.........
Old Jan 7, 2009 | 11:12 PM
h2guy's Avatar
h2guy
When first starting, the oil press indicator, "flops" up to mid-range within 1/2 to 1 sec after initial firing. But, oil press indicator symbol, does'nt disappear
until 2-3 seconds after firing.
Where do each of these receive their input from?? Why the significant lag??
Old Jan 8, 2009 | 12:28 AM
87 F-150 I6's Avatar
87 F-150 I6
I have noticed that my oil gauge takes a half sec or less to flip up when started, don't know if that normal, what kind of oil are you running. Thicker oil might make a difference vs thine oil.
Old Jan 8, 2009 | 09:50 PM
h2guy's Avatar
h2guy
15-40 Rotella for 218k miles.
Old Jan 8, 2009 | 09:55 PM
Ponyboychris's Avatar
Ponyboychris
Mine behaves the same way. I think you are fine.
Old Jan 8, 2009 | 09:59 PM
fxstbchopper's Avatar
fxstbchopper
Yeah that is how mine is I believe it is standard nothing to worry about.
Old Jan 8, 2009 | 10:45 PM
Pocket's Avatar
Pocket
Ford's gauges are really nothing more than a glorified dummy light.
Install a trans temp gauge, then compare it to the stock dash gauge. You'll see why.
Old Jan 9, 2009 | 07:47 AM
Ponyboychris
Good point!!!! Nuff said.
Old Jan 10, 2009 | 08:38 PM
h2guy's Avatar
h2guy
CHeck signature. 01's don't have tran temp gage. I do have a tranny temp gauge installed tho. We're talking OIL press here and their senders.
They have to come from two different sources and I'd like to know from where.
Old Jan 10, 2009 | 08:55 PM
Pocket's Avatar
Pocket
It's still the same concept, regardless of the gauge you are talking about.
Heck, the PCM on automatics doesn't even track coolant temps at all. The coolant temp sensor goes only to the gauge on the dash, and nothing else.
As for oil temps, pressure, etc, or any other gauge..... Ford has specific ranges they consider "normal". As long as the input to the gauge or PCM registers in the "normal" range, the gauge will stay right in the middle. So again, it's nothing more than a glorified dummy light, and nothing more.
Old Jan 10, 2009 | 08:57 PM
MAKO314's Avatar
MAKO314
the oil sender is the one on top of the hpop resivore if I'm thinking correctly.
fxstbchopper
The sending unit is on the HPOP reservoir the light is delayed because of the fact that the PCM has to read that the pressure is right before it shuts the oil light off.
