Sponsored by: Innova
Radio Wiring
Old Jan 7, 2009 | 08:23 PM
ramrod7373's Avatar
ramrod7373
Radio Wiring
I got a Jeep radio for a box I built for my UPS truck and it has no plug in the back. The wiring diagram is on the back. I see it has speaker feed and speaker return. Is the feed the positive and return the negative?
Thanks
Old Jan 8, 2009 | 12:54 AM
ReAX's Avatar
ReAX
Not really. Speakers use AC current. If you want to think of it as +/- you can, but it's not accurate. In your UPS truck you probably will not be able to hear if the speakers are out of phase so it's not going to be a big deal if you do wire the speakers wrong. Use the feed as the + on the speakers and you should have the right phase.
Old Jan 8, 2009 | 12:57 AM
ReAX's Avatar
ReAX
Just a cool trick, The + side on the speaker means if positive DC current is applied, the speaker will move away from the magnet. I've read not to use more than 1.5v but, up to 9v should be fine. To test the speakers for polarity, put the battery on the two wires, when you have the Pos battery on the pos lead, the speaker will move forward. Only tap the leads, don't hold them on the battery.
RichardPerry
Electrical Systems/Wiring
Apr 9, 2012 10:15 PM
glovemeister
Jul 31, 2011 03:07 PM
jared66
1997 - 2003 F150
Jan 16, 2010 04:34 PM
va98expd
Jul 25, 2004 09:07 AM
greymule
Oct 11, 2002 01:42 PM
