it's a bit icey out
Old Jan 7, 2009 | 02:06 AM
Auburn_in's Avatar
Auburn_in
it's a bit icey out
I went a little out of bounds tonights. just bent the running board. I got lucky
Old Jan 7, 2009 | 02:13 AM
Auburn_in's Avatar
Auburn_in
I was able to straighten it out a little but it's still not perfect.
Where's the best place for an oem replacement? probably need brackets too. prices?
Old Jan 7, 2009 | 02:21 AM
ReAX's Avatar
ReAX
I know the early flat boards were made by cord. Westin makes a non-lighted that is nearly identical, however the Cords were the OE manuf. I am not so sure about the lighted, the lighting styles have changed several times over the decade. They might be more difficult to track down.
Old Jan 7, 2009 | 02:28 AM
Auburn_in's Avatar
Auburn_in
Maybe I'll take them off when I lift it andput power steps on
Old Jan 7, 2009 | 01:15 PM
Immortal_Ben's Avatar
Immortal_Ben
Glad to hear that damage was limited to a running board!
Old Jan 10, 2009 | 10:11 PM
da X-man's Avatar
da X-man
How did that happen?
Old Jan 11, 2009 | 01:53 AM
Auburn_in's Avatar
Auburn_in
road was icey. I was "feathering"the gas. getting the back end to come loose. guess I over did it. Started sliding towards the curb, into someone's yard. fron end came about 3 feet from a 1 foot diameter tree, (lucky) back end whipped into some kind of rock surounding a bush or small tree, missed that thing (luck #2) and stopped about 4 inches between a tree stump and rear bumper. (lucky #3) got out, check my truck and the property. nothing of their's was damaged so I left. got home to check out my truck a little closer and took those pics. Rocks must have damaged the running board. Rocks/paver stones. whatever they are. Was only doing about 25 mph at the time, tops. I do that all the time and keep it under control. I can drift in a circle like in the dukes of hazzard movie. but I guess even when you stand, looking over the edge of danger so many times, you're bound to lose your balance sometime. just a good thing I didn't fall over that edge.
Old Jan 11, 2009 | 01:54 AM
Auburn_in's Avatar
Auburn_in
Sorry for the large pictures. my cell phone takes better quality pictures than my actual camera.
