Odd dtc code...at least to me.
Old Jan 6, 2009 | 07:12 PM
jsw22250's Avatar
jsw22250
Got in the truck to go to work this morning and since it was raining I had the wipers on intermittent and headlights and radio on. 99 f250 with 120k . It kept stalling out instantaneously. Sometimes it would just hiccup and sometimes die out completely. I replaced the cps with the new gray one about a year ago and I do have a spare but this is unlike that. I did find a reference to a similar story in the archives. Dtc codes are p1249, p0500, and p07a00. From what little I can store in my tiny brain the first two are normal on a programmed truck but I can't find a reference to the p07a00. Any ideas about any of this. Thanks in advance. Jsw22250
Old Jan 6, 2009 | 07:19 PM
rbaker6336's Avatar
rbaker6336
do you have a programmer?looks like the one I got with hypertec
Old Jan 6, 2009 | 07:21 PM
fxstbchopper's Avatar
fxstbchopper
You said it was raining and you have a 99 there has been a leak in the windshield that most can't see and it will leak onto the back of the fuse panel check to see if it is wet on yours.
Old Jan 6, 2009 | 07:23 PM
jsw22250's Avatar
jsw22250
I do have a hypertec programmer. But no leak in the windshield that I know of. Where does this occur. jsw22250
Old Jan 6, 2009 | 07:26 PM
jsw22250's Avatar
jsw22250
Whereabouts does this leak generally show up at. The fusebox being wet or at the dash level?
Old Jan 6, 2009 | 07:29 PM
fxstbchopper
Most have found the gem and the fuse box wet and did not see a leak so the leak was not noticeable.
Edit: the Gem sits on the fuse panel.
Old Jan 6, 2009 | 07:42 PM
jsw22250's Avatar
jsw22250
Cool. OUt to the truck I go. jsw22250
Old Jan 6, 2009 | 07:43 PM
rbaker6336's Avatar
rbaker6336
When you lose the hypertec you will lose the goofy code
jsw0767
Oct 19, 2014 11:03 AM
the deno
Jun 21, 2013 01:53 PM
2buck
Nov 26, 2012 10:55 AM
Tia Maria
Apr 18, 2012 08:09 AM
jsw22250
Aug 28, 2007 04:45 PM
