Ignition coil
Old Jan 6, 2009 | 11:03 AM
vettman's Avatar
vettman
Ignition coil
Can someone please tell me what the primary resistance should be on a standard/OEM-replacement coil. My volt-ohm meter reads .2 ohms. Is that okay?
Old Jan 6, 2009 | 12:57 PM
bryyce62's Avatar
bryyce62
Sounds about right.
Old Jan 6, 2009 | 01:31 PM
Alvin in AZ's Avatar
Alvin in AZ
My primary's 1.1 ohms
~10,000 for the secondary
560 ohms for the distributor stator
1100 +/- 100 ohms for the Ni-wound ignition wires depending on length
Alvin in AZ
Old Jan 6, 2009 | 03:00 PM
fmc400's Avatar
fmc400
MSEE
0.2 ohms is way too small. With a resistance that low, most of the voltage is going to drop across the resistance wire, giving you a smaller primary voltage, which leads to a smaller secondary voltage and hence a very weak spark. Additionally, with a resistance that small, the coil will draw more current than it should and will run hot. Your coil is close to failure and should be replaced. Your primary resistance should be around 1.0 ohms, not much more, not much less.
Old Jan 6, 2009 | 05:54 PM
vettman's Avatar
vettman
ignition coil
This is a brand new coil. I tested two in the store before I left with my purchase and both tested at .2 ohms, also. My old coil tested at .2 ohms before it was replaced. I replaced it because it was 33 years old, and I was replacing the connector cap so decided to go with a new coil.
Old Jan 6, 2009 | 06:31 PM
fmc400's Avatar
fmc400
MSEE
With only 0.2 ohms on the primary winding, the voltage divider created between the coil primary and the resistance wire upstream in the harness will only leave the coil primary with around 20% of the voltage. That's too small. Furthermore, every spec chart I have ever read specifies around 1.0 ohm for the coil primary resistance. A 33 year old coil, or coils picked up from the parts house (that are most likely foreign made) do not set the bar, nor do they trump solid circuit theory.
Please see the following:
http://econtent.autozone.com:24991/z...5280053a9a.gif
murph77's Avatar
murph77
I don't want to hijack this thread, but what contacts are used for this test? I'm going to replace my cap and rotor soon, but I never would have thought to test for ohms at the coil.
Old Jan 6, 2009 | 06:36 PM
fmc400's Avatar
fmc400
MSEE
Primary winding: Probe between BATT and TACH terminals on the coil (see my previous post).
Secondary winding: Probe between large center terminal and BATT terminal on the coil (separate test, see this link: http://econtent.autozone.com:24991/z...5280053a97.gif)
Old Jan 6, 2009 | 06:40 PM
murph77's Avatar
murph77
Good stuff. Thanks fmc400.
Old Jan 6, 2009 | 06:47 PM
Alvin in AZ
At this point it sounds as if his meter ain't reading right. :/
If it's an analog you blew on the face of it, right? ;)
Huffing and blowing on my meters' faces is automatic for me.
Glass, plastic either can build static and bogus readings can send you
looking in the wrong direction when hunting trouble.
Murph, now that you are thinking;) read some voltages and resistance of
stuff... like the stator coil and while you have the wires off the cap read
the ignition wires, even new ones can have an open.
Didn't know off hand the spec was 1 ohm for the coil, my post came from
my notes written in my shop manual. :)
IMO that's a cool thing about a book vs a CD manual.
Spec or no spec if my coil's resistance changes, it's out of there. ;)
Alvin in AZ
Old Jan 6, 2009 | 06:57 PM
murph77's Avatar
murph77
Oh yea, just want to clear up one more thing (for all of us dummies). Do these numbers apply to all engines? I reviewed this thread and noticed it didn't seem to be specific to any one engine. Should I use these guidelines for testing my 300?
Old Jan 6, 2009 | 07:13 PM
fmc400's Avatar
fmc400
MSEE
Yes, you can use them for your 300.
Old Jan 6, 2009 | 07:53 PM
murph77's Avatar
murph77
I feel stupid.
Old Jan 6, 2009 | 08:05 PM
Alvin in AZ
I feel stupid.
Cool! :)
That makes you a knowledge sponge! :)
Hmmm... are you trying to take my "dumbest guy on FTE" title? :/
Alvin in AZ
Old Jan 6, 2009 | 08:13 PM
vettman's Avatar
vettman
I'm using a digital meter that I have no reason to believe is inaccurate. I've also checked the resistance with an old Sears engine analyzer that I used back when one of my cars had a points-type ignition. It read .2 ohms also. I'll try a different parts place tomorrow and have them test one of theirs. This is becoming a good thread; I appreciate everyone's input.
