engine sounds funny with new chip installed
Old Jan 6, 2009 | 10:12 AM
robjs111's Avatar
robjs111
just installed a 5 position chip on my 2001 f350 7.3. originally purchased a 40 hp chip from BTS a while back. sent chip back to BTS and had a switch with 4 more tunes installed, 80 econ, 100 race, 100 smoke, and high idle. after installing engine seem to be making funny marble like sounds coming from bottom of motor. removed chip all together and truck sounds and runs great. What is wrong???
thanks.
rob
Old Jan 6, 2009 | 10:32 AM
Pocket's Avatar
Pocket
If I were you I would call BTS and talk to Cale. See what he thinks.
It could be a number of things from fuel, to oil, to timing, to injector health, etc. A well tuned chip shouldn't cause the engine to make too much extra noise. Mine gets a bit louder on some of the higher HP tunes when the engine is cold. Once the engine warms up, they all sound pretty much the same.
Old Jan 6, 2009 | 01:10 PM
DieselBeast01's Avatar
DieselBeast01
I'm with Curtis on this one...call BTS and see what they say. I have the DP tuner on mine and the truck sounds the same in all the tunes except for 140 Aggressive. It's a little louder, but still runs smooth.
Old Jan 6, 2009 | 01:53 PM
robjs111's Avatar
robjs111
u think i should sell bys chip and buy a dp chip??
Old Jan 6, 2009 | 02:19 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Selling that chip to get a DP is something you will have to decide. I don't know anything about the BTS chip. I do know I like my DP.
Old Jan 6, 2009 | 04:11 PM
Pocket's Avatar
Pocket
If you already have the BTS chip, I would say keep it. Cale does a good job at tuning these trucks.
Old Jan 6, 2009 | 04:32 PM
DCSpecial's Avatar
DCSpecial
I agree that I would call Cale, I've heard good things about his tuning ability.
Old Jan 6, 2009 | 04:59 PM
big poppa's Avatar
big poppa
I know when i push the button on my DP, switching from different selection of tunes, i hear the engine get louder when i up the setting, lower the setting, it gets quieter.. Somebody here a week ago had a clip of himself in his truck going thru the settings on his DP, noticable change the way the motor sounded. I'll see if i can find it.
Old Jan 6, 2009 | 08:27 PM
F350-6's Avatar
F350-6
Did you ever call Cale to see what his thoughts were? I don't see any reason to switch to DP. Let Cale fix the issue.
