I have an 88 F 250. WHen I lock in the hubs and use 4hi.....I will hear a growling noise for 3-10 seconds that will actually slow the truck and then it will go away...... only happen again at an un expected time. When I have the hubs locked in and I am in 2hi.......same thing........
When I am in 2hi and the hubs are unlocked.......No Problem!
Could be a bunch of things. U-joints, bearings in the front differential, etc.
I'd lock the hubs, leave it in 2HI and turn the front driveshaft by hand and see if there's any slop in any u-joints (both in the driveshaft, and the axles) or in the differential gears.
