Sponsored by: Real Truck
help: LONG TRANNY WARM UP TIME!!
Old Jan 5, 2009 | 10:23 PM
Buckboard6-300's Avatar
Buckboard6-300
Hi I Drive A 2003 F-250 With A 5.4 Litre Gas Engine I Have Noticed That In The Cold Temps Of -15-35degrees Celcius The Motor Will Warm Up Slightly After 3 Min But The Automatic Tranny Is Definatly Not. I Start To Drive Down The Highway I Notice That The Tranny Takes A While To Shift Into The Other Gears, During The Summer With A Moderatly Light Foot, The Tranny Would Shift At 2000 Rpm But In The Cold When The Tranny Is Not Warmed Up It Takes An Extra 300 Rpm To Shift Or Just Will Not And The Rpms Will Climb To 2200 And Hold There Until The Tranny Is Warm By The Way It Takes 6 Miles For The Tranny To Warm Up!!! I Have No Idea What Is Going On Or If Anything Is Serriously Wrong Please Help!!
Old Jan 5, 2009 | 10:57 PM
aphotic26's Avatar
aphotic26
I have had the same problem....I'm also lost for words.
Old Jan 5, 2009 | 11:00 PM
Buckboard6-300
it must be our canadian climate!!
Old Jan 6, 2009 | 12:05 AM
Fordfanatic4life's Avatar
Fordfanatic4life
sounds normal enuf to me..
the tranny fluid is just really cold and as a result takes longer to get to operating temp. and so will the tranny in general..
i wouldnt worry about it, unless the tranny starts acting up like missing shifts and such..
p.s. i notice my tranny temp. gauge has been alot slower to come off full cold, with the nasty weather.. no worries...
Old Jan 6, 2009 | 01:30 AM
_Rick_'s Avatar
_Rick_
Hi Buckboard,
You might want to check your trans fluid level just in case, but I can't help but feel your concern is nothing to be worried about. When it hits colder than normal temps around here (Vancouver BC area) I find myself feeling that the Truck is running a little strange. From feeling every minor rough spot on the road (frozen tires) to the shift points not hitting the sweet spot as it does in normal (warmer) weather conditions.
Of course I cannot guarantee it, but I'm pretty sure you're ok.
How long has it been since you had the tranny serviced? Fluid and filter might help if it's been a long time since last service.
Rick...
Old Jan 6, 2009 | 02:42 AM
Pocono Super Duty's Avatar
Pocono Super Duty
It is the nature of the beast. They all do the same thing. There is nothing wrong with your transmission.
Old Jan 6, 2009 | 05:37 AM
shorebird's Avatar
shorebird
What I believe is happening is the engine thermostat is doing its' job and staying closed allowing the engine to warm properly. However the transmission is circulating fluid through its' portion of of the radiator. A solution maybe the installation of a thermostatic bypass valve to the transmission lines. What transmission do you have? Does it have a built-in bypass?
FROM Tru-Cool 4739 MAX - Diesel Performance Parts
1999-2004 Ford 4R100 Transmission
1999-2003 Ford 7.3L Powestroke
1999-2004 Ford Lightning
1999-2004 Ford F-Series Gasoline Engine Vehicles
all of the above are already equipped with a bypass valve and the valve is not necessary
If you have any other model of transmission, you will need to check with your repair manual or parts department to see if your transmission is equipped with a bypass valve. If it is, you don't need one. We know that 1994-1996 E4OD transmissions DO NOT have a bypass and will require the unit with the bypass valve. The bypass valve will help these vehicles maintain minimum operating temps of the fluid.
Old Jan 6, 2009 | 08:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That extra 300RPMS sounds like the torque converter not locking up until the tranny is warm.
Quite normal.
How to fix it? A thermostat bypass would probably help.
Or at that temp, maybe a heater blanket for the tranny? Is there such a thing?
Old Jan 6, 2009 | 09:04 AM
aldridgec's Avatar
aldridgec
Extra 300 rpm sounds normal at those temps. Unless it's something new, or just been a while since it was that cold and you forgot, I would not worry about it. Everything works differently when it's cold.
Old Jan 6, 2009 | 10:14 AM
dkf's Avatar
dkf
Its normal. I monitor trans temp. The TQ will not lock until temp are at a certain point. I can drive for over 10 minutes during the winter and my trans isn't near 100 deg F. My TQ will usually lockup before the engine temp reaches 180 deg but thats with temps around 20 degrees.
I'm shure Mark will chime in.
Old Jan 6, 2009 | 11:52 AM
redford's Avatar
redford
You might change your fluid. Flushing the transmission and changing to a synthetic fluid (like Royal Purple MAX ATF) might help a bit.
Old Jan 6, 2009 | 03:44 PM
jim henderson's Avatar
jim henderson
My experience, with at least 3 cars when I lived in the frozen wasteland of the Pacific NW, was that the cars would not shift at the warm shift points until the car had been at freeway speed for a few miles. Usually the shift points were about 500rpm higher than usual. I think this is the computer delaying shift points to warm up the fluid.
I have an ATF temperature guage on my F250 and it will stay pegged at the bottom of the guage for a long time when the weather is really cold. Might take an hour or two at cruising speed before the needle gets above 150 if it is freezing out.
Course now I live in So Cal so who worries about cold temp tranny performance.
Jim Henderson
Old Jan 6, 2009 | 04:08 PM
Buckboard6-300
ok thanks every body that is what i was hoping for because it did get worse as the weather gets colder and no i dontknow what tranny type it is and i dont know what a thermostat bypass is but i appreciate the help and on a slightly warmer day than -20 celcius i will check the trans fluid. thanks again guys
Old Jan 6, 2009 | 04:30 PM
_Rick_'s Avatar
_Rick_
Quite normal.
Where can I find one of these tranny heating blankets? I've got $30.00 burning a hole in my pocket.
Old Jan 6, 2009 | 05:01 PM
krewat's Avatar
krewat
While it's funny once in a while, like the hub heaters, I was being serious. Too many practical jokes drives users away
