Cat delete pipe
Old Jan 5, 2009 | 02:12 PM
Mike8623's Avatar
Mike8623
Cat delete pipe
OK guys, where can I get a cat delete pipe............Cheap, or who has them at the most inexpensive price......Best deal around
96 F250 7.3 powerstroke, mostly stock
Old Jan 5, 2009 | 02:21 PM
Eric_F250's Avatar
Eric_F250
i got mine at tymar. great quick service
Old Jan 5, 2009 | 02:56 PM
Hussler's Avatar
Hussler
If I had to do over I would of gone to muffer shot and had them cut the old one out and weld in a piece of pipe .. was quoted $50. Getting the CAT off the old exhaust pipe was not a fun job, as was putting the CAT delete on without destroying something else.
Old Jan 5, 2009 | 07:27 PM
charlie92/7.3l's Avatar
charlie92/7.3l
i took mine out sunday it took 1h 30m start to finish 24in long 4in pipe took the flang out un hooked the clamp took down the support brakits the two at the front got a 4ft 2x4 hit it like i was swinging a ax it came out fast cut the cat off so the 4in fit tight it will fit over the rear use a ball pin hammer to tap the edge down you will need a welder and a saw .
Old Jan 5, 2009 | 08:47 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Look here: Diesel Truck Performance Parts & Accessories Under Ford Powerstroke on the left, then engine size: Diesel-7.3L, then: Then year: 199?, then Exhaust products, then 1994-97 Ford Powerstroke Down Pipe and Test Pipes, then Delete/Test Pipes-200, then submit. $61.99 in Stainless Steel.
Old Jan 5, 2009 | 08:56 PM
2 stroke man's Avatar
2 stroke man
hey, dont go buying no expensive pipe. i went to the local muffeler shop, they cut mine out, put in a new pipe for $20, and then i sold the dang cat for $40
Old Jan 5, 2009 | 09:02 PM
charlie92/7.3l
who do you sell the cat to
don77's Avatar
don77
just make your on i got welder i make that stuff ill the time or the muffler shop cuss them pipes are to high becuss its just i short little pipe
Old Jan 5, 2009 | 09:47 PM
Eric_F250's Avatar
Eric_F250
i kept my cat just in case the inspector yells at me next year. the piece i put in is really just a spool piece that can be replaced when i'm done "testing for track or off road use" cuz it would be unscrupulous to remove an emissions control device... right...?
Pridnjoy
Apr 13, 2014 12:09 PM
dmncoon
Nov 11, 2008 09:24 PM
firebug
Feb 21, 2008 12:58 AM
richsoucie
May 18, 2007 12:59 PM
bruno6491
May 14, 2007 07:19 AM
