add-a-leaf questions
Old Jan 5, 2009 | 10:58 AM
1994diesel's Avatar
1994diesel
so my front suspension is needing replacement. the front shocks are shot and the leaf springs are sagging. so my questions are what brand is most recommended for an add-a-leaf and does anyone know of any sites with good prices for an add-a-leaf?
thanks guys
Old Jan 5, 2009 | 11:04 AM
ghunt's Avatar
ghunt
Are you sure the springs are sagging and it's not the shackles?
Shackles helped a good bit on mine and my truck only has 98K on it.
Also, with add-a-leafs the thing would bruise your kidneys (I bought add a leafs over a year ago, just sold them because I realized I didn't really want to run them)
Old Jan 5, 2009 | 11:55 AM
1994diesel's Avatar
1994diesel
um idk, how can i tell if its my shackles? i just replaced them recently to.
Old Jan 5, 2009 | 12:04 PM
Lazy K's Avatar
Lazy K
For add-a-leaf kits try stengelbros.com you get new U-bolts and everything you need.
Old Jan 5, 2009 | 12:16 PM
1994diesel's Avatar
1994diesel
ok thanks, i will check it out.
Old Jan 5, 2009 | 01:13 PM
starmilt's Avatar
starmilt
Also check the spring bushings and bolts these wear out and let the truck ride low.
Old Jan 5, 2009 | 02:22 PM
joe f350's Avatar
joe f350
or have u put on some weight lol
Old Jan 5, 2009 | 02:56 PM
catfish101's Avatar
catfish101
You have to watch those add a leaf kits. I sen the added leafs that didn't match the others. The arch will be different and that will not let the leafs carry the weight evenly. What I mean is if you add a leaf and you can see an uneven gap from the axle out then that is bad.
I had a leaf added to one of my trucks at a spring shop for not much more then one of those kits and the leafs were matched as a set.
Old Jan 5, 2009 | 03:01 PM
starmilt's Avatar
starmilt
Catfish wear have you been we was afraid them reindeer stranded you somewhere.
Old Jan 5, 2009 | 03:21 PM
1994diesel's Avatar
1994diesel
all of the bushings are good, like i said i just recently replaced the front shackles. i dont know to much about suspension, but i am going to attempt to replace the shock absorbers and add a leaf by my self at home. i only have 2 leafs on each side in the front on my 94. i don't think it will stiffen it up any more than it is now because it is pretty much riding on the frame rails.
anyone got any more good websites?
thanks again for the help!
Old Jan 5, 2009 | 03:30 PM
ghunt's Avatar
ghunt
If it's that bad, I'd recommend replacing the springs. Putting on an add-a-leaf would just be like putting a band-aid on there.
Old Jan 5, 2009 | 03:37 PM
1994diesel's Avatar
1994diesel
alright. so add a leaf is more for a lift? jeez that means spending more money.
would putting new shock absorbers help out my dead springs a little bit?
Old Jan 5, 2009 | 03:44 PM
catfish101's Avatar
catfish101
Adding a leaf isn't just for lift. If the arch doesn't change then then lift would just the thickness of the spring. The truck may raise raise some because of the added support of the other spring.
Shocks won't help your springs. Shocks are for keeping your tires on the road. I guess a heavy enough shock could help with support for a weak spring but it would have to be a shock for something bigger then your truck.
Star, I have been around just pretty busy. This is my busy time of year.
Old Jan 5, 2009 | 03:51 PM
joe f350's Avatar
joe f350
i think he put on some weight over the holadays lol u should lift ur truck if ur repalceing to the front springs
Old Jan 5, 2009 | 03:57 PM
1994diesel's Avatar
1994diesel
Originally Posted by joe f350
i think he put on some weight over the holadays lol u should lifter ur truck if ur repalceing to the front springs
hahaha! i must have cause my suspension aint getting any better!
yea, an add a leaf is cheaper than replacing it all, i was hoping to get away with it.
joe f350, how much should i lift it? i was thinking about 2 inches, but ur probably thinkn 12 inches!!! lol
