JUST LOOKING FOR A LITTLE HELP? MY 05 6.0 WILL NOT FIRE UP NOW. THE LAST TIME I GOT IT STARTED IT LOPED REAL BAD WITH LOTS OF BLACK SMOKE, SO THEN I TURNED IT OFF. TRIED AGAIN, TURNS OVER, ACTS LIKE ITS GONNA START WITH MORE BLACK SMOKE BUT NEVER WILL STAY RUNNIN. A FEW DAYS BEFORE THAT WHEN COLD (20-30) IT WILL KIND OF START ROUGH WHEN I DONT PLUG IT IN BUT IF TRY TO DRIVE IT WITHOUT IT BEING WARMED UP IT ACTS LIKE IT IS GONNA DIE. THEN I PLUGGED IT IN AND WENT TO LEAVE AND DID THE SAME THING ONLY NOT AS BAD. NOW ITS SITTIN AT THE SHOP. ANY SUGGESTIONS??
I would run something thinner than that in those temps and synthetic if its in the budget. Locally the ford shop puts 10-30 year round. When was the last fuel filter change,the filters need to be clean with cold fuel. Have you looked at the EGR valve?
