Bronco II Ford Bronco II
Fuel Filter
Old Jan 4, 2009 | 11:09 PM
Army_Dave's Avatar
Army_Dave
Fuel Filter
Ao i got bored and decided to change my fuel filter. no knowing if it needed it or not. But seems the common notion is to replace it when you can. I bought the truck 2 months ago. Any way heres a pic of the filter that came out, can you guys tell me if it was ok ? or if it was due for a change? thanks.
Old Jan 5, 2009 | 05:15 AM
kernel-panic's Avatar
kernel-panic
Which filter was it? The low-pressure one on the frame rail under the driver's side near the door or the high-pressure one on the driver's side frame rail about dead even with the front axle? Unfortunately, I can't see photobucket pictures. If it's the low-pressure one and a bunch of trash came out of the plastic holder with the filter element, then it was possibly in need. That one usually catches a lot of the garbage from the fuel tank before it hits the other filter and should be changed more often, IMO.
1L243
Oct 20, 2015 07:34 PM
CoachMikeSC
Aug 15, 2015 03:24 PM
Painted Horse
6.7L Power Stroke Diesel
34
Feb 13, 2013 07:59 AM
willj86
Sep 25, 2005 05:46 PM
joefran
1983 - 2012 Ranger & B-Series
Aug 2, 2004 07:49 PM
