Vacuum Advance Question
Old Jan 4, 2009 | 07:46 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Shouldn't the distributor vacuum advance line in this photo be connected to where the red cap right behind the primary float bowl is now?
Old Jan 5, 2009 | 08:27 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Have to make this 10 letters, but yes.
Old Jan 5, 2009 | 05:10 PM
LxMan1's Avatar
LxMan1
Sweet choke cable
Old Jan 5, 2009 | 05:18 PM
BradyCouchman's Avatar
BradyCouchman
and there is also a hose that doesnt go anywhere...or is that the vacume advance? but i agree that where the red cap is could be a location for the hose but not the only i would guess...
Old Jan 5, 2009 | 07:06 PM
fun_suv's Avatar
fun_suv
Thats the vacuum hose for the trans. The vacuum advance should go where the red cap is, and the trans vacuum should go where the vacuum advance is currently. Thats what we were thinking at least.
Old Jan 5, 2009 | 09:39 PM
LxMan1's Avatar
LxMan1
Yep, the vacuum advance needs to be hooked to the red plug (ported vacuum on metering block) after the initial timing is reset with no vacuum attached to the advance.
It's definitely going to have pinging issues and possibly hard to start hot issues.
As for the choke, I would use a thin metal rod and lock it on the cable holder on the vacuum pod and connect it to the choke lever. Much cleaner insulation.
Old Jan 6, 2009 | 11:08 AM
BradyCouchman
i would agree that that would work....
Old Jan 7, 2009 | 03:54 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just curious. What is the engine in and what do you know about it? I remember some wicked 6 bangers years ago. With that Offy manifold, headers, and 4 bbl. someone has done some work.
Old Jan 7, 2009 | 04:00 PM
SteveBricks
FTE Emeritus
It's in a '58 1/2 ton. It's got roller rockers and an other than stock grind on the cam but that's about all I know..
Old Jan 7, 2009 | 04:22 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Sweet! Love it when someone takes a different path. Should run fine w/ton's of torque.
Old Jan 7, 2009 | 04:30 PM
fun_suv's Avatar
fun_suv
Inline 6's are sweet to build up. Just like the old Datsun Z's everyone drove in college , and those dyno queen Supras and stuff.
longview1
Feb 23, 2015 09:32 PM
MitchD
25
Jan 6, 2011 03:27 PM
M6EV139445
Dec 4, 2006 04:52 PM
kermit
Apr 18, 2004 11:35 PM
