Lifting Dually
Old Jan 4, 2009 | 02:59 AM
benbe71's Avatar
benbe71
Lifting Dually
I was looking around at sites for a lift kit for my dually (Just bought an 2001 CC LB 4x4 DRW 6-Speed) I wanted to know if I can use a lift kit from a SRW F-350 or will that not work. Tried the search could not find what I was looking for Thanks.
Old Jan 4, 2009 | 03:10 AM
Alex332's Avatar
Alex332
Lifted duallys are SICK!!!! I'm not a fan of the HUGE lifts.
4" looks tight!
Old Jan 4, 2009 | 12:18 PM
DCSpecial's Avatar
DCSpecial
Only difference is the rear u-bolts used. Dana 80 axle tubes on the DRW are larger diameter and need larger u-bolts.
2000-2004 F350 DRW 4wd - Truck Toyz Store
Old Jan 4, 2009 | 12:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If youre going to lift it, and it's a superduty with leaf springs, Icon Vehicle Dynamics is the only way to go. Used to be Donahoe.
Old Jan 4, 2009 | 02:18 PM
benbe71's Avatar
benbe71
Thanks guys thats just what I needed.
Old Jan 4, 2009 | 02:21 PM
DCSpecial's Avatar
DCSpecial
I should add that all the ones on our site in the DRW link that I posted already come with the correct size rear u-bolts.
Old Jan 4, 2009 | 02:36 PM
jdecker88's Avatar
jdecker88
It depends on the truck and the ammount of lift that you put on a dually to make it look good I have seen some great ones but I have seen some butt ugly ones too. Also you will probably lose some of your maximum load capability.
Old Jan 4, 2009 | 02:41 PM
benbe71's Avatar
benbe71
Lol yeah I know what you mean there are some ugly ones, Plus I don't really mind loosing some of my load capacity cause I never use it to haul anything.
Heres my inspiration lol.
Old Jan 4, 2009 | 02:42 PM
DCSpecial's Avatar
DCSpecial
Load capacity will depend on the method in which the rear is lifted.
You can go to a 8-10" lift and still keep your stock load capacity in the rear if you use One Up Offroad Traction Blocks in the rear.
Old Jan 4, 2009 | 02:44 PM
DCSpecial's Avatar
DCSpecial
Pretty sure that's a 4.5" Icon (or 5.5") since it's an 05-07.
He's running 22s with 36.5" BFG MTs
Old Jan 4, 2009 | 02:47 PM
benbe71's Avatar
benbe71
How much lift would I neeed for an 01? Would a 6" be good?
Old Jan 4, 2009 | 02:49 PM
DCSpecial's Avatar
DCSpecial
Yep, 6" should clear that tire/wheel combo.
May have to trim the lower valance of the front bumper a little or shim the bumper if you run a stock bumper.
Old Jan 4, 2009 | 02:51 PM
benbe71's Avatar
benbe71
Cool thanks again
