Sponsored by: Real Truck
Front Springs
Old Jan 3, 2009 | 09:45 PM
BMOHIO's Avatar
BMOHIO
Question Front Springs
Any buddy know the color marking of front springs on a F-250 4X4 ?
I have two sets
one is orange / blue / yellow
The other is gray / brown
I think it is weight capacity
Old Jan 3, 2009 | 09:57 PM
kelly67's Avatar
kelly67
scroll down towards the bottom it gives you codes for springs an diameter of springs but i haven't heard of color code!
https://www.ford-trucks.com/forums/4...lder_____.html
Old Jan 4, 2009 | 12:16 PM
DCSpecial's Avatar
DCSpecial
You can look at the sticker that's on the driver's side door jamb, look for "FRONT GAWR" the number by it will tell you what springs you have.
Or by "SPR" it will give you the spring codes.
Old Jan 4, 2009 | 02:31 PM
spr1516's Avatar
spr1516
where can i find 6000 springs
Old Jan 4, 2009 | 02:39 PM
DCSpecial's Avatar
DCSpecial
Dealer or Ed the FTE Partsguy on here.
I upgraded my 07 to 7000lb coil springs up front.
Old Jan 4, 2009 | 03:16 PM
spr1516's Avatar
spr1516
now im looking to go up to the 6000 i have the 5200 with a leveling kit by me goin to the 6000 springs up front would that screw me up in the drive line or brake line??
Old Jan 4, 2009 | 03:20 PM
DCSpecial's Avatar
DCSpecial
I think you'd only gain 3/4" of height or so.
What year is your truck?
DCSpecial's Avatar
DCSpecial
duplicate post.
Old Jan 4, 2009 | 03:41 PM
spr1516's Avatar
spr1516
2006 f250 i have the 5200 on there now an im gonna be putting a snow plow an i dont want any sagg like i see some SDs
Old Jan 4, 2009 | 04:06 PM
DCSpecial's Avatar
DCSpecial
What size leveling kit?
Did it come with the alignment cams to correct caster?
Old Jan 4, 2009 | 05:25 PM
spr1516's Avatar
spr1516
2in leveling kit an it was the fabtech one the one with under the coil cup
Old Jan 4, 2009 | 05:41 PM
DCSpecial's Avatar
DCSpecial
It doesn't appear that the Fabtech includes anything to correct the caster.
If you get poor handling, more wandering and any "death wobble" especially with any increased height by swapping coils you'll need to get some cams to give you more positive caster to correct that.
I run the cams that Icon uses with their 2.5" leveling system on my stock height 07 with 7000lb coils for better handling.
Old Jan 5, 2009 | 12:16 AM
BMOHIO's Avatar
BMOHIO
Springs
Right out of a Ford F-250 Workshop Manul
Front Springs #
CODE R = F81A-5310-ABB 3600 Lb
CODE S = F81A-5310-ACB 4000 Lb
CODE T = F81A-5310-ADB 4400 Lb
CODE U = F81A-5310-AEB 4800 Lb
CODE V = F81A-5310-AFB 5200 Lb
CODE W = F81A-5310-AGA 5600 Lb
CODE X = F81A-5310-AHA 6000 Lb
My Vehicle Certification Label
FRONT GAWR 5200 Lb
But the SPR CODE is TT CC
AND T is F81A-5310-ADB 4400 Lb
But the # on the spring is F81A-5310-AEB 4800 Lb
This is why I was looking for the coloer code..
Areyouliving
Jan 29, 2016 05:20 PM
jcs1966
Apr 18, 2015 09:12 AM
kras498
General Automotive Discussion
Mar 12, 2015 11:43 PM
4CFarms
Aug 22, 2014 01:24 PM
march
Mar 12, 2014 08:10 PM
