Sponsored by: Real Truck
which oil
Old Dec 2, 2008 | 07:30 PM
fairchase's Avatar
fairchase
which oil
Hey glad to be on the forum.
I just bought a 2001 250 SD 4x4 to use on the farm. I was surprised to see the oil cap said 5w20. I'm not used to oil that light. Are most of you running this and if so are you using dino or syn?
Thanks for any imput
Old Dec 2, 2008 | 07:38 PM
Angrywasp's Avatar
Angrywasp
Ummm. If it's a diesel I think it should be 15w-40 for the 7.3 and 6.0 not sure for the 5.4 or 6.8.
Edit: After a quick search it sounds like you have a gas and that 5w-20 is what is called for from 01 up. It was 5w-30 before that apparently.
Old Dec 2, 2008 | 07:39 PM
Blue'87GT's Avatar
Blue'87GT
My '03 V10 I am using Motorcraft semi-synthetic 5w20 per the factory owners manual. BTW, I find that it is the same or cheaper than Castrol GTX which goes into my Bronco!
Old Dec 2, 2008 | 08:03 PM
bullsco's Avatar
bullsco
oil choice
Hi, yeah I have a 2005, 4x4, F250 SD, Crew SB with the 5.4 (82000 kms) and I use a good quality synth oil. The local shop had a good deal on Royal Purple so I'm using it right now. For years I've been a Quaker State guy and loved their product however, Castrol has been catching my interest recently and I think I'll give them a try after the R/P runs out at the local shop.
Old Dec 2, 2008 | 08:32 PM
Blue'87GT's Avatar
Blue'87GT
Just like John Force--Castrol GTX--DRIVE HARD!
Old Dec 2, 2008 | 08:56 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Mobil1 full synth. 5W20
thats whats in my F250
Old Dec 3, 2008 | 09:34 AM
Big Orn's Avatar
Big Orn
Welcome to FTE, fairchase!
What engine? How many miles? What oil is used now - or was used by previous owner?
There's nothing wrong with dino oil at all as long as it's a good grade.
And there's nothing wrong with synthetic oil as long as your engine will accept it. Sometimes if an engine has run on dino oil all its life, synthetic oil will find away to escape - either by evaporation or gaskets.
I vote for dino - Castrol GTX
Old Jan 4, 2009 | 10:13 AM
jbrown91's Avatar
jbrown91
Don't use Quaker Sludge or Penzoil, they both sludge. Also most newer, like 1990 and up, Ford engines are supposed to have 5w-20. Ford spent a lot of money in R & D to figure out that the 5w-20 is better for their engines as opposed to 5w-30.
The modular engines have tiny passages for the oil to get through and the 5w-20 is really needed. I personally use Motorcraft oil. I can get a 5qt jug at Wal*Mart for $12.50, otherwise $2.50 a quart, and it is a synthetic blend. Also you will need a FL-820S oil filter if you go with Motorcraft, like $3.80 for the filter. The filter are made by Wix, so they are good. Don't use a cheap brand like Fram for filters, unless you like having engine problems and actually spending more for the filter.
Valvoline and Castrol make a good oil, but for the price you can't beat the MC oil.
5.4 V8 takes 6QTs and 6.8L V10 takes 6 or 6.5qts depending on where you look.
Old Jan 4, 2009 | 12:13 PM
spr1516's Avatar
spr1516
i use royal purple with a k&n filter always have on my trucks an will never go back runs great!
Old Jan 4, 2009 | 01:41 PM
azfordf100man's Avatar
azfordf100man
Are you serious? Pennzoil/QS do not sludge!! That is an old myth back when Penn/QS contained Paraffin in them a long time ago.
As a matter of fact Pennzoil is one of the best oils on the market, especially Pennzoil Platinum Synthetic(check UOA's).
But I do however agree with you on Motorcraft, proven to be a great oil at an unbeatable price.
Old Jan 4, 2009 | 03:36 PM
jbrown91's Avatar
jbrown91
Well they must have really changed them. When I've seen engines with a pan coated full of sludge at teh shop. Asked the mechanic about the truck, he laughed a little and said the guy used the "best" since new, Quaker State.
Old Jan 4, 2009 | 04:02 PM
azfordf100man
This is one of those rumors that will just not go away. No biggie though, I used to think the same thing until I did some research. BTW, didn't mean to come off rude in my above post, sorry if it came off that way.
That sludged car probably had either bad maintenance/sludge prone/clogged pcv/coolant leak, etc. Doubt it was from the oil "If" it was changed regularly.
Old Jan 4, 2009 | 05:48 PM
GT4point6's Avatar
GT4point6
6.8's take 6-7 qts depending, use the dipstick. Mine takes 7 to get to the full mark and that is exactly what the owners manual calls for. It's a 2005.
5W-20 or 5W-30 is fine. Ford changed to the -20 in 00 or so for "economy" in that the lighter oil provides less resistance and is more "efficient". In a SD with a 6.8, your not going to see those gains at all. Clearances didn't change when they went lighter, oil pump didn't change, bearings didn't change, just trying to get a better "efficiency" rating. I use 5W-30 since I tow a lot and it gets hot in SoCal in the summer going over the mountains.
YMMV
Kevin, 05 250 SD, XLT Sport V10, 4x2, 4.10, CC, Torqueshift towing the #63 CMC Mustang
Old Jan 4, 2009 | 10:23 PM
jbrown91's Avatar
jbrown91
I'm just talking about the engine does have some tight passages to begin with.
Old Jan 4, 2009 | 10:51 PM
motown's Avatar
motown
Penzoil Platinum, $23 for a 5qt jug and Motorcraft filters for $3.80,at Wally World.
