Sponsored by: Kumho
Which tires fit?
Old Aug 30, 1999 | 05:28 PM
Snapper_Rider
Guest
Posts: n/a
Which tires fit?
I have an '84 F150 longbed 4x4 and am thinking about getting 13 inch tires. Will these tires fit without a suspension lift or anf fender trimming? Thanks
Old Aug 30, 1999 | 09:07 PM
H8monday's Avatar
H8monday
Which tires fit?
What do you mean by 13" tires? That would be the rim size of say a Honda Civic or a light weight trailer. Are you sure that is what your looking for? If it was a Typo and your looking into 33" tires,well thats a different story,(and would probably look and perform better on your truck). 33" tires should fit but will be limited in their travel and clearance. I would suggest at least a 2" lift to accomadate the 33" meats.
Jeff
Old Aug 31, 1999 | 07:23 AM
jcd302's Avatar
jcd302
Which tires fit?
If you mean 31. No Problem. That is what I have on my 94. 33's might need a little lift, but not sure.
Jason Dawson
Tried, True & FORD Blue
Old Aug 31, 1999 | 02:25 PM
slik's Avatar
slik
Which tires fit?
Hey Jeff,
What do you think I could go to on my '82 F150 2WD? How wide and how tall? (I know I need to change out my 2.73 rear first, but I'm tryin' to plan ahead.)
Thanks,
Slik
Old Aug 31, 1999 | 02:40 PM
H8monday's Avatar
H8monday
Which tires fit?
Slik,
What are you planning on doing with the truck? Is it slated for off road use or street? Let me know what your looking to acomplish,Power,mileage,towing,etc and Ill look through my guides and charts.
Jeff
Old Aug 31, 1999 | 03:04 PM
Pastmaster's Avatar
Pastmaster
Which tires fit?
>Hey Jeff,
> (I know I need to
>Thanks,
>Slik
There's alot of people in my area, that have 2wd 1/2ton's and the largest i've seen is 31X10.50. The look really good on a 2wd w/o any lift!!!
Old Aug 31, 1999 | 03:09 PM
slik's Avatar
slik
Which tires fit?
Looks and power; no off-roading
Slik
Old Aug 31, 1999 | 03:29 PM
H8monday's Avatar
H8monday
Which tires fit?
I would go with something like 30 x 9.5 15 BFG All Terrains with 3.55 gear ratio. Or a 31 x 10.5 15 with 3.73 gears. Both would fit well on any 15 x 8 Wheel. your RPMs would be about 2600 at 65 MPH. You should be well into your power band at that range,but still get fair MPG.You could also go to say 4.10 gears and get an after market overdrive for the HWY(about $2000).That would be a sweet set up. It actualy gives you OD in all gears.Just something about as your planning ahead.
Jeff
Old Sep 1, 1999 | 12:21 AM
slik's Avatar
slik
Which tires fit?
Thanks Jeff,
It gives me a lot better idea of what direction I should be looking.
Slik
Old Sep 2, 1999 | 02:33 PM
slik's Avatar
slik
Which tires fit?
FordBoy2012
1997 - 2003 F150
May 11, 2023 08:20 PM
Dogmann
Jun 22, 2014 04:16 PM
Muzzy33
Dec 15, 2012 06:42 PM
bkuuz1
Nov 13, 2010 10:14 AM
Chris89lx
Oct 10, 2006 09:21 PM
