Sponsored by: Kumho
PITA Rotor Removal
Old Jan 3, 2009 | 11:28 AM
scflowmaster's Avatar
scflowmaster
PITA Rotor Removal
I recently put on new rotor and pads on my 01 Expedition. It took about 9 hours to do the front brakes. I figured that I would show you what kind of hell I went through. but I cant figure out how to but pics on here so follow this link to see them.
http://www.cardomain.com/ride/3151276/2
Old Jan 4, 2009 | 07:04 AM
Lazy K's Avatar
Lazy K
At least you got it done. You have come to the right place. You will find this is the best truck forum bar none.
Old Jan 4, 2009 | 06:44 PM
vetteguy96's Avatar
vetteguy96
Why did it take so long?
Old Jan 4, 2009 | 08:52 PM
scflowmaster
the rotors were seized on so bad. The re-assembly took 10 minutes, it was getting the rotors off that took so long. I used every trick in the book to get them off.
Old Jan 5, 2009 | 12:28 PM
vetteguy96's Avatar
vetteguy96
Man, that sucks
Old Jan 5, 2009 | 12:59 PM
andym's Avatar
andym
I just saw that you live in Michigan. That would explain it. Glad you got it done. Just imagine what a shop would have charged if it had taken them that long.
Old Jan 5, 2009 | 02:40 PM
Lazy K's Avatar
Lazy K
Forgot to add, I think if you add pics to the FTE gallery you can include them with your post. Not sure as I have never done it.
Old Jan 8, 2009 | 06:19 PM
MassSupra's Avatar
MassSupra
A 4 foot long sledgehammer has always worked for me. Sometimes they come off in pieces but it's alot quicker.
Old Jan 9, 2009 | 11:30 PM
Gevans17's Avatar
Gevans17
Those are the nastiest rotors I have ever seen!
Old Jan 18, 2009 | 08:10 PM
micgang's Avatar
micgang
Yikes, the worst ones I ever did were the stock rear rotors on my 02 Exploder. I was going to turn them and reuse them, but I had to beat the tar out of them to get them off. Oh well. My situation was nothing compared to yours... Hopefully you cooled off with a nice brew...
Old Jan 19, 2009 | 08:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
i use an air chisel on the rotor to axle flange surface to shock it, them whack the outer edge of the rotor with a 5 lb dead blow hammer. it has never taken me more than 3 tries to get the rotors broke loose.
Old Jan 19, 2009 | 04:01 PM
bashby's Avatar
bashby
the expeditions have this problem, I've had to cut several off
Old Jan 19, 2009 | 09:29 PM
blacklab3113's Avatar
blacklab3113
I just replaced my rear rotors and pads on Saturday. I'm the fool who loaded the pads in backwards on one wheel. I know your pain, I usually take an 8ft 2x4 run it out the other side placing one end against the exposed part of the rotor (with help) and beat the hell out of the end of the 2x4 with a sledgehammer. With out a lift, and working on stands it's the only effective method I have found. Had to do it on my rear rotors this weekend in 13 degree weather. But hey, I saved a ton of money!
DISLFVR
Oct 15, 2012 09:12 PM
carbonmetallic
Feb 6, 2009 07:21 AM
someday
Jan 13, 2006 12:29 AM
someday
Jan 12, 2006 10:42 PM
skooch
15
Nov 14, 2005 03:16 PM
