99 F350 Tranny Problem
Old Jan 2, 2009 | 08:54 PM
Outlaw Trucker's Avatar
Outlaw Trucker
I bought a 99 F350 4x4 w/ auto trans - 268K miles.Tranny shifts weird- real soft & slow. 1st & 2nd almost slips into 3rd, & real fast into the rest. Put shift kit in - not much better. Bought a junkyard tranny with 85K - does the same thing. Is this computer problem?? Not looking for a new tranny - I want to get this figured out. If not, I also have a 94 4x4 Power Stroke w/ 5spd. Will this bolt up to the 99 (clutch, p. plate, flywheel, & housing)? I don't care about appearance or resale. Have a 08, 99, & 94 - all F350 4x4's. This is the first auto trans I've had - don't much care for it. Any help would be greatly appreciated. Thanks!!
Old Jan 2, 2009 | 09:16 PM
fxstbchopper's Avatar
fxstbchopper
Welcome to the FTE..
It sounds odd I would have said the trans is on it's way out but one with less miles doing the same thing of course with a used trans there is no guarantee it is a good trans either . Did you flush the trans and replace the fluid and filter? There is a guy on here Mark that knows a lot about these transmissions so give it some time to see if he shows up.
Edit: And I don't believe the older trans will bolt up with modifying.
Old Jan 2, 2009 | 09:40 PM
leekingen's Avatar
leekingen
Mite Be You'r Pcm ? Change Out To A Later One Pmt 1-ptm 2 - Or 3 Will Help With Shift Or Get A Dp Or Tony Wildman Chip.
Old Jan 2, 2009 | 09:45 PM
F350-6's Avatar
F350-6
Welcome to FTE. What kind of shift kit did you put in? Did it come with a separator plate for the accumulator valve body? If so, have you tried drilling larger holes in the separator plate?
I just installed a TransGo tugger kit in my wife's new 01 and that made a difference. Sonnax makes some modulator valves to help firm up the shifts. Like you, I'm used to the stick, but there are plenty of options out there for the autos.
carlislefordf250
25
Jun 23, 2014 06:59 PM
Kert0307
Modular V10 (6.8l)
Nov 27, 2010 10:37 PM
grantorino
Feb 19, 2007 02:03 PM
dtm1
May 14, 2005 10:54 PM
PHS79
1997 - 2003 F150
13
Mar 5, 2003 10:47 PM
