Injectors finally
Old Jan 2, 2009 | 01:23 PM
97 HD's Avatar
97 HD
Injectors finally
I scored a Saturday off and got approval from headquarters (A.K.A wife) so im gonna pull my injectors out tomorrow and send them to Rosewood for stage 1's. Im gonna inspect the injector cups, and harnesses while they are out. I already have new GP's what else might i need to look at while im in there.
Im gonna do other stuff while the truck is down. Wheel bearings, and some engine cleanup. I thought about painting my turbo black and leave the Garrett lettering aluminum color, any thoughts on that. How hot does it get? Duplicolor has hi heat paint up to 1200* IIRC.
Old Jan 2, 2009 | 04:07 PM
live2wheel's Avatar
live2wheel
just got done do'in the same thing with injectors. sounds like you got it all covered. get ready to lay on the radiator for awhile.what fun. swivel sockets are really cool for the back bolts on the valve covers. oh yea, and dont drop nothin'.
Old Jan 2, 2009 | 05:24 PM
c00nhunterjoe's Avatar
c00nhunterjoe
stubby wratchet wrenches are nice too.
the turbo can get over 1200 but hopefully not for long...lol most header paint should hold up decent on the turbo
Old Jan 2, 2009 | 07:04 PM
97 HD's Avatar
97 HD
What is the torque speck on the injector bolts for the reinstall. I dont have a torque wrench, can i just get them gud-en-tite (LOL) or do they need to be specific.
Old Jan 2, 2009 | 07:06 PM
c00nhunterjoe
i've never torqued them, i go pretty snug on them
Old Jan 2, 2009 | 07:34 PM
tjbeggs's Avatar
tjbeggs
I painted my turbo with the 1200 paint and its good to go. Its been over 6 months and its still black so it should be fine.
Old Jan 2, 2009 | 07:35 PM
c00nhunterjoe
i hate rusty stuff, maybee i will paint mine too. i have several cans of black heat paint here. sounds likea quick project for tomarrow. did you grind the rust off of yours tj?
Old Jan 2, 2009 | 08:02 PM
tjbeggs's Avatar
tjbeggs
I was swapping the housings at the time so I threw the housing in the blasting cabinet. The center section just had some slight surface rust on it and I just painted over it. Both look good still. Hardest part was masking off the intake side!
Old Jan 2, 2009 | 08:03 PM
c00nhunterjoe
definatly, i dont have mine off, (obviously) so i dont think it will stick very well to my housing
Old Jan 2, 2009 | 09:52 PM
live2wheel's Avatar
live2wheel
if you wanted to know the torque on the injectors its 10 ft lbs. if they're not torqued enough , the copper crush gasket will leak and burn up.
Old Jan 3, 2009 | 12:01 AM
foxracing0934's Avatar
foxracing0934
Here is the write up that i used, TikiWiki : 94 through 97 Injector R&R it has all of the torque specs that you will need
Old Jan 3, 2009 | 12:43 AM
97 HD's Avatar
97 HD
Thanks to live2wheel, and foxracing0934 for the info. Reps sent.
I was looking at the duplicolor web site, it says after applying their hi heat paint (1200*) the part should be baked in an oven to cure the coating. Im wondering if grill (BBQ) paint will work?
Old Jan 3, 2009 | 06:20 AM
stephen.south's Avatar
stephen.south
O reilys has some 2000 degree paint that I used to paint my new turbo housing, so far so good. very limited colors though (all flat paint) I also had to bake mine. I put it in the oven though, I don't think you want flames, just the heat
Old Jan 3, 2009 | 09:12 AM
tjbeggs's Avatar
tjbeggs
I didn't bake mine even though it said to. just let dry and the exhaust heat will do the rest!
