Stupid Ccv Re Route Question!
Old Jan 1, 2009 | 11:03 PM
Stroked Out!'s Avatar
Stroked Out!
wHAT ARE THE RESAONS/BENIFITS OF THE MOD SORRY FOR THE DUMB QUESTION?
Old Jan 1, 2009 | 11:43 PM
bismic's Avatar
bismic
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>
It keeps the intake and intercooler free of oil so it is more efficient at cooling the incoming air. It also keeps the blow-by oil off the intercooler boots which can make them deteriorate.
from cartmanea ... posted in another thread.
</TD></TR></TBODY></TABLE>
Old Jan 2, 2009 | 10:02 AM
jmaskew's Avatar
jmaskew
I think this is a stupid question...
Why can't you just add a filter to the stock setup instead of rerouting it down to the frame? Wouldn't this filter out all the oil? I have read that a lot of guy's put a filter inline when they do the reroute.
Old Jan 2, 2009 | 10:45 AM
bismic's Avatar
bismic
That is what I did - I mounted the filter on the frame rail.
Old Jan 2, 2009 | 11:23 AM
jmaskew's Avatar
jmaskew
Thanks Mark! How to you know when the filter gets full? I have been searching for a filter housing with a drain valve but can't seem to find one. I'll keep looking.
Old Jan 2, 2009 | 12:02 PM
bismic's Avatar
bismic
I bought mine from a person on another forum - it is a home made type job. Racor makes an expensive one and so does BD.
<TABLE style="WIDTH: 693pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=924 border=0 x:str><COLGROUP><COL style="WIDTH: 693pt; mso-width-source: userset; mso-width-alt: 33792" width=924><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 693pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=924 height=17>Racor Filter - the Rcaor filter is designed to last about 750 hours in diesel operation.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 693pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=924 height=17>http://www.maesco.com/products/racor/r_ccv_intro/r_ccv_intro.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 693pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=924 height=17>http://www.allpointsmarineco.com/view/243/592/</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl27 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>BD makes one for over $300 smackers !</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>http://www.dieselperformance.com/ind...uct/index/152P</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 693pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=924 border=0 x:str><COLGROUP><COL style="WIDTH: 693pt; mso-width-source: userset; mso-width-alt: 33792" width=924><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 693pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=924 height=17>You can build your own (for under 50 bucks) -</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 693pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=924 height=17>http://guzzle.rbmicro.com/ccv1.html
I drain mine every oil change. I have a pint glass jar I keep in the truck to periodically check the diesel I am getting (mid fill-up) for water and crud. I use it to see how much oil I get from the ccv filter. I do not ever drain enough to worry about filling the jar up. The filter is fairly large.
The Racor is pretty fancy - you should take a look at it.
(ps Jonathan - you have a pm)
Old Jan 2, 2009 | 12:18 PM
riggz's Avatar
riggz
Filtering it back into the intake is just another way to do it. The only reason I went with running a hose down the frame is it was easier, cheaper, and doesn't put the hot air/gases back into the intake. keeps the intake air flow smoother as there isn't that angled fitting sticking up in the middle of the intake tube.
Old Jan 2, 2009 | 02:33 PM
jmaskew's Avatar
jmaskew
Thank you Mark for all the info!! The Racor filter is nice!
