73 with low compression ratio
Old Jan 1, 2009 | 06:17 PM
playdopyromaniac's Avatar
playdopyromaniac
73 302 low compression problem
does anyone know where i can get taller pistons so i can get a higher compression ratio since 73-76 302s have a taller deck height
Old Jan 1, 2009 | 09:20 PM
cipsmithers's Avatar
cipsmithers
Maybe this is a dumb question, but whats a tall deck 302? Never heard of one.
Old Jan 1, 2009 | 09:46 PM
Alvin in AZ's Avatar
Alvin in AZ
Never heard of one.
Yes it is a dumb question but just so happens to be the only kind I'm
qualified to -guess at- (the best I can). :/ So thanks for asking it. ;)
Deck height is the distance from the top of the piston to the top of the
cylinder. Doesn't matter if it's a cast iron block like a 302 or a Motorcycle. :)
I'd never heard of a "tall deck 302" either. :)
But I fiNgure I knowed what it was tho. ;)
My '75 360FE just so happens to suffer from the same "problem" but not
because of the block but instead because of its short-topped pistons.
Alvin in AZ
ps- my very first air cooled VW engine I rebuilt I guessed at the deck
height and guess wrong and had to take it apart again and shim under
the cylinders, I bought a deck height measuring tool right after that. ;)
Old Jan 1, 2009 | 09:56 PM
playdopyromaniac
tall deck is just a generic term because 73-76 302s had a taller deck height by 20 thou
Old Jan 1, 2009 | 10:04 PM
Fordworth's Avatar
Fordworth
Deck height is actually measured from the centerline of the crank to the top of the deck.
Old Jan 1, 2009 | 11:52 PM
cipsmithers
Alvin in AZ
Ok now I'm in the know.
Old Jan 2, 2009 | 12:58 AM
393STROKER's Avatar
393STROKER
Summit-Jegs catalogs
Old Jan 2, 2009 | 12:59 AM
monsterbaby's Avatar
monsterbaby
Actually the smart move would be to deck the block, this has 2 purposes. First brings the deck back down to the old height and secondly straightens up the deck surface (squares the block ) which all blocks almost always need anyway.
trike1946
Dec 9, 2013 07:50 PM
Jarryd
Mar 6, 2013 09:16 AM
playdopyromaniac
Jan 9, 2009 03:36 AM
dehamma
Jan 9, 2004 02:16 PM
Ben_E
15
Jun 27, 2002 12:42 AM
