Sponsored by: Real Truck
information console
Old Jan 1, 2009 | 11:50 AM
deeretek's Avatar
deeretek
information console
2004 F250 SD Diesel am looking add the over head info console. Have found some parts on ebay but has anyone done this? Any help would be greatly apprieciated.
Old Jan 1, 2009 | 02:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
Some folks have but to get it fully functional you'll need the outside ambient air thermometer, too. It goes behind the grill, in front of the radiator and to the right as you're looking at it. The harness may be there.
You might wanna consider a Scan Gauge II. They are cheaper and give you more displays than you can shake a stick at. Whereas the OEM gives you MPG & Distance To Empty, the SCII takes it new levels allowing you to monitor tranny & other temps, every conceivable MPG display and a ton of other stuff. It doesn't tell you which direction you're going or what the temp is outside but really?...does anyone need that?
Roll down your window to see how warm or cold it is and look at either the sun or your GPS to determine your direction.
http://scangauge.com/ <----click to learn a bit about it. I think it'd be worth your investment. I know it was for me.
Welcome to FTE!
Old Jan 1, 2009 | 06:53 PM
deeretek's Avatar
deeretek
I had been looking at that for a while. Probably the way to go, easy instal. Thanks for the input. Nice Excursion! If I did not tow a 5th wheel, I'd have one
i eat hybrids
Aug 13, 2012 05:39 PM
Chance_Thomas
16
May 5, 2008 10:34 PM
gruz1
2004 - 2008 F150
Mar 8, 2005 09:13 AM
PaulC
Nov 16, 2002 10:29 PM
rockcrawl
Apr 26, 2001 03:49 PM
