Help
Old Jan 1, 2009 | 11:46 AM
str8racing's Avatar
str8racing
Help
While changing the water pump on my 90 f350 7.5 l I broke the front cover on the engine behind the pump. Anything I can do?
Old Jan 1, 2009 | 11:58 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Buy a new timing case and replace it???
What would you want to do?
If you don't care about quality they're cheap enough on Ebay.
Old Jan 1, 2009 | 12:05 PM
str8racing's Avatar
str8racing
How hard to change?
Old Jan 1, 2009 | 06:47 PM
str8racing's Avatar
str8racing
I never broke a timing cover before,got one coming tomorrow, hopefully not to hard to change.
Old Jan 1, 2009 | 07:15 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by str8racing
How hard to change?
If you have the pump off you're 90 percent of the way there.
Get a timing gasket set. (and a scraper)
Don't forget the bolts coming *up* from the front corners of the oil pan.
Use sealant on bolt threads going into or through water jackets. (I like Locktite PST)
You need to pull the harmonic balancer, so borrow a puller and make sure to check the surface that the seal will ride on is smooth.
You would want to check the timing chain for slop while you're in there, but I think the later FI models have a straight up double roller chain that lasts much longer than the silent link hy-vo type chain on my carbureted model.
Other than that, I don't have a serpentine setup so I can't be too specific about what else to look out for.
I hope this helps.
Old Jan 1, 2009 | 08:36 PM
str8racing's Avatar
str8racing
Thanks it does help.
Old Jan 3, 2009 | 11:33 AM
str8racing's Avatar
str8racing
Does anyone have a pic. of front of engine (460) I cant remember how to put alternator brackets back together,thanks.
Old Jan 3, 2009 | 12:39 PM
jadmt's Avatar
jadmt
Old Jan 3, 2009 | 01:08 PM
str8racing's Avatar
str8racing
Thanks, it helps.
Old Jan 4, 2009 | 03:03 PM
str8racing's Avatar
str8racing
Finished it up today, thanks for you're help. Next time I will look for hidden bolts.
