Sponsored by: Real Truck
Check Engine Light / Stalling Issue HELP!!
Old Jan 11, 2009 | 11:42 PM
995.4SD's Avatar
995.4SD
Im with redford, my money is on a throttle position sensor.
Old Jan 12, 2009 | 08:11 AM
bdavis1369's Avatar
bdavis1369
The exact code is " Idle Air Control Fault"
Old Jan 12, 2009 | 12:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
The scanner your buddy used did not translate the code properly, since you don't have an IAC.
What was the exact code? They are a letter followed by 4 numbers. It would be something like P0122 if my hunch is correct, but there are many things that could have caused your symptoms. We can only take a WAG unless you get the code.
Old Jan 19, 2009 | 02:55 PM
bdavis1369's Avatar
bdavis1369
OK ....I just ran the scanner again and it is CODE P0506 Idle Air Control System RPM Lower Than Expected
Anyone have an ideas where I can Start???
Old Jan 19, 2009 | 03:22 PM
Mustang6147's Avatar
Mustang6147
P0506 code ussually also will throw a second code. Like Backfire or somthin like that. P0506 is generally just low rpm's ??? translated threw the computer. did anything get sucked up threw your intake hose, maybe plugging your filter??
Old Jan 19, 2009 | 03:25 PM
bdavis1369's Avatar
bdavis1369
ill go check now....I looked at the air filter the other day and it was a little dirty but not anything that would trow a code...ill go check the intake hose right now....
Old Jan 19, 2009 | 05:30 PM
bdavis1369's Avatar
bdavis1369
There are no obstructions that I can find.....I disconnected the battery for 10 min to clear the computer. When I reconnected it the code is gone and it SEEMS to be running better. Ill see how it gotes tomorrow and post the results....THANKS!!
Old Feb 1, 2009 | 07:52 PM
bdavis1369's Avatar
bdavis1369
Well. The problem went away for a day and NOW ITS BACK!!
Guess Im going to have to take it in to the stealership...
Old Feb 1, 2009 | 08:49 PM
redford's Avatar
redford
There is no secondary code or pending codes?
Old Feb 2, 2009 | 09:12 AM
bdavis1369's Avatar
bdavis1369
no...just the one code.....I cant figure it out
Old Feb 2, 2009 | 04:12 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
my 350 was doing the same thing , i cleaned the maf sensor and all is well you had it tore down to it take it out a clean it simple its worth a try ! it worked for me
Old Feb 10, 2009 | 01:12 PM
bdavis1369's Avatar
bdavis1369
Problem solved
I did what fountain, et al said, I took the mass air flow apart and douched it with MAF cleaner....including the sensor in the air flow tube and WOLAA....runs like a top.....throttle is very sensitive and feels like I added 30 hp....also, smooth idle at 750 ish rpm and no stalling.....
THANKS EVERYONE!!!!!
Old Aug 5, 2010 | 11:09 PM
  #28
twigsV10's Avatar
twigsV10
I had the same thing on my 06 v10 I cleaned a bunch of crud out of the TB runs grate
chrisdvorak
Mar 15, 2015 10:14 AM
rwinsouthla
Sep 30, 2012 01:41 AM
psu152
Apr 29, 2009 07:36 PM
csherman4383
Mar 27, 2004 02:13 PM
Junior57
Mar 25, 2004 01:06 PM
