Sponsored by: Auxito
Bad ball joint
Old Dec 31, 2008 | 08:25 PM
40LUTZAG's Avatar
40LUTZAG
Bad ball joint
on my 97 4x4 the inner tire on drivers is worn baed. I assume its the ball joint. how do you know if its the upper or lower? dO YOU NEED TO REPLACE BOTH?
Old Dec 31, 2008 | 08:31 PM
torkum's Avatar
torkum
A quick test is to jack the wheel in question up and grab the tire at the top and bottom. Shake the tire and you should feel any extra play at the top or bottom that would indicate a bad upper or lower ball joint problem. Also grab the side and shake to check for play in the tierod.
Old Dec 31, 2008 | 11:40 PM
mjunk1's Avatar
mjunk1
Don't wait on it. I took forever to check mine and the lower was literally in two pieces. Only the weight of the truck was keeping it together. Scary!
Old Jan 1, 2009 | 09:06 AM
steve(ill)'s Avatar
steve(ill)
the lowers always go first. if you jack it up, you need to jakc under the lower A- frame so the tire is off the ground, but in the normal position. you can not jack under the truck frame and let the tire "hang". get it 2 inches off the ground. put the endge of a 4 ft 2 x 4 under it and pry up and down. look at the lower joint while doing this.
Vinford
2009 - 2014 F150
22
Apr 13, 2011 12:07 PM
stang3O2
1997 - 2003 F150
Feb 25, 2009 09:39 PM
gene17847
Jul 29, 2008 10:28 PM
icantdo55
Jun 14, 2007 08:43 PM
Greg Gilmore
Feb 27, 2004 05:59 PM
