Dome Light
Old Dec 31, 2008 | 06:26 PM
7.3 Rocket's Avatar
7.3 Rocket
Dome Light
My dome light doesn't work.
Does anyone know what fuse it is? Also how difficult is it to remove the cover of the dome light to check/replace the bulb?
The two courtesy lights next to the dome light that operate by the switches both work. The dome light doesn't work when the door opens or when I click the little wheel that dims the gauges all the way up.
I'm not going out to the truck to check anything and I just remembered that my dome light doesn't work. I haven't really looked into it yet.
It's far too dark and far too cold for me to go work on a light on a truck I can't drive yet, but I'd just like to know for future reference.
Edit: I did try searching for a thread that had this information in it, but I was unable to locate one.
Old Dec 31, 2008 | 06:33 PM
megawatt00's Avatar
megawatt00
Does the light in the rear of the truck, on the roof, near the bed come on?
Old Dec 31, 2008 | 06:36 PM
7.3 Rocket's Avatar
7.3 Rocket
The brake light? I dunno. I haven't let anyone else drive the truck so I've never seen the brake lights and I only know the turn signals work because I could see them reflecting on the snow. I'll see if I could get dad to stand behind the truck and look tomorrow morning.
BTW: We've always called that the cyclops light. Probably not the techical term for it, but it fits.
Old Dec 31, 2008 | 06:38 PM
megawatt00's Avatar
megawatt00
On my 01 there are lights on the outside of the brake light that light up when the door's are open.
Old Dec 31, 2008 | 06:39 PM
Bigcat350's Avatar
Bigcat350
Pete
I just did mine a couple weeks ago and its no problem. The cover will pop right off. Try removing from the front side first. Turn on the 2 small lights and you can see where it will release from.
Old Dec 31, 2008 | 06:42 PM
7.3 Rocket's Avatar
7.3 Rocket
Ok this is bothering me too much to not know if those lights go on or not. I'm going to go get a flashlight and some warm clothes and I'll go outside and check. Anything else I ought to check when I'm out there? It's COLD and snowy so I really don't want to go out more than once tonight.
Old Dec 31, 2008 | 06:44 PM
PaysonPSD's Avatar
PaysonPSD
What Jim is getting at is if the cargo lights come on then it probably isn't the fuse but the lamp.
RussB's Avatar
RussB
I would check to see if the bulb is good... Thats where I would start if I were you !!!
Old Dec 31, 2008 | 06:52 PM
7.3 Rocket's Avatar
7.3 Rocket
No lights at all come on when I open my door.
Can someone point me in the right direction for the sensor in the door? It's probably right there in my face, but it was cold and dark out. I just checked the thermometer and it said 14 degrees. In case you can't tell cold and snowy aren't quite my favorite things.
Old Dec 31, 2008 | 07:11 PM
7.3 Rocket's Avatar
7.3 Rocket
So. Seems like a fuse or bad switch to me. What do you guys think? Does anyone know what # fuse it is so I can check it?
Old Dec 31, 2008 | 07:27 PM
PaysonPSD's Avatar
PaysonPSD
Under dash fuse 14 - 10 amp
Old Dec 31, 2008 | 07:28 PM
7.3 Rocket's Avatar
7.3 Rocket
Thanks! Reps sent!
Old Dec 31, 2008 | 07:50 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by 7.3 Rocket
Thanks! Reps sent!
Your Welcome and thank you.
If you don't have an owner's manual you can get one here in PDF LINK
Have a Happy New Year!!!!!!!!!!!!!!!!!!
Old Dec 31, 2008 | 09:33 PM
rjmay's Avatar
rjmay
I took the dome light off once and when I reinstalled it - no light.
The two mounting screws provide the ground - took the light off again and reinstalled and it then worked
Old Jan 1, 2009 | 11:03 AM
7.3 Rocket's Avatar
7.3 Rocket
Well I pulled the #14 fuse out today and it looks just fine. The plastic is still clear and I can still see the little metal piece inside. What do I do now?
