last week we had some good snow i didnt get it all off and off course it packed up on the window 2 days later the wipers were working then just stopped they still dont work i checked the fuse its good i beleive same fuse for washer pump and the washers sprays the fluid is there another fuse , a known issue or am i going to have to repalce the wiper motor btw if you use the rain X washer fluid even if the wipers stop the window will clear at speed
Under the dash there is a fuse #11 for a 2000 anyway not sure what year your truck is. Then there are two relays under the hood in that fuse panel again for a 2000 #34 and #35. I would check them you may try tapping on the motor with a hammer if it comes back on then I would say replace the wiper motor.
Did you check the 30a fuse under the hood in the #15 position..? ( 5th one from the back of the box, on the left).. This is the main fuse for the wiper motor for your 99)..
DANG SON on the head again walked out counted to 5 popped it out
its bad
if you were really cool youd tell me where i can get one of those HUGE ones on new years eve at 730 at night
Have a happy new year one and all and as always thanks so much for all the help over the last couple of years i wish i could contribute half as much as as i have been given
Most gas stations which has service bays should have it..Or Walmart if they are still open..
To contribute, you might want to consider becoming a "Supporter"... Have a Safe New Year...
i used the one that charges the trailer battery # 16 to get me through the night as im not taking the trailer out tonight
and yea its time to be a supporter
my first thing to do in the new year
