Headlight switch
Old Dec 30, 2008 | 09:13 PM
cornfedp's Avatar
cornfedp
Headlight switch
I believe I have narrowed my dash light problem down to the headlight switch. #1 I get intermittent power at the fuse for the dashlights. #2 I installed a different instrument cluster. So, why the serial number break for the headlight switch? The chain store has neither but what is the difference in them in case they get the wrong one.
Old Dec 30, 2008 | 09:32 PM
Edgar C's Avatar
Edgar C
Hi there this is my first post and I hope I help with my comment,
I had the intermittent problem also and yes it was the light switch, I got a new one and no problems since.
Old Dec 30, 2008 | 09:54 PM
cornfedp's Avatar
cornfedp
Thanks for the reply Edgar C and welcome to the boards.
Old Dec 30, 2008 | 10:05 PM
hotroddually's Avatar
hotroddually
take the old switch with you to compare the new one to it. it should have the same plug in on the back for it to work with your trucks wire harness. make sure all the pins on the back for the plug are the same. some have more or less pins so compare and get the same one.
thowle65
Feb 11, 2015 09:00 PM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
FedExguy2004
Oct 24, 2004 10:16 PM
firsttimeFordowner
Aug 16, 2004 01:07 PM
STiNGeRX
1983 - 2012 Ranger & B-Series
Jun 8, 2001 10:06 PM
