Sponsored by: Auxito
Headlight restoration
Old Dec 30, 2008 | 07:18 PM
98FordTruck's Avatar
98FordTruck
A friend recently told me about a process where you can restore your old cloudy yellow headlights to a crystal clear like new finish. I contacted Glass Doctor and they will do it for $90 but I have never seen it done before and am unsure of how well it actually works. Has anyone used this and how well does it work? Are there any recommended DIY kits out there? I would much rather spend the $90 than $300 a piece for new headlights.
Old Dec 30, 2008 | 07:28 PM
n5926g's Avatar
n5926g
I used Micromesh on mine,and they looked good as new.We use this compound on Radar indicator faceplates.It has a graded grit polishing system.
Ive never looked for it in the retail market since we have it at our office.
The use of the kit requires quite alot of elbow grease,but its worth it.
You might try to Google it,or just do a search on the web.If you find its what you want,but cant find it,PM me and Ill hook you up....
Old Dec 30, 2008 | 07:44 PM
Old93junk's Avatar
Old93junk
Spend 3.95 on a bottle of Mothers chrome polish, It does just as good a job as anything else ever will ,and the price is right.
Old Dec 30, 2008 | 07:56 PM
98FordTruck
n5926g,
Thanks for the tip. I Google'd micromesh and found this website. I will check it out and see what I can find. I'll let you know how it turns out. Thanks again.
Old Dec 30, 2008 | 07:57 PM
98FordTruck
Forgot the link, here ya go.
Micro Mesh Acrylic Plastic Kits for use with Power Tools
Old Dec 30, 2008 | 08:59 PM
n5926g's Avatar
n5926g
Originally Posted by 98FordTruck
n5926g,
Well..That IS the correct manufacturer,ours come in a box with small abrasive sheets in varying grits from coarse to fine,it also comes with the bottle of polish,polishing cloth,and soft rubber block.
I WISH it had the power pads...would make my muscles much happier
Guess the boss orders the commercial grade instead of the retail grade....at any rate,Ive restored the headlights in my f-150,as well as 3 eclipses,2 talons,and a 3000gt...its a good investment in my book.
Old Dec 30, 2008 | 09:29 PM
ididntdoit99's Avatar
ididntdoit99
I got my aftermarket projector headlights off of ebay for like $125. Obviously, like others have said, you can clean up your headlights for much cheaper than that, but for the money, new headlights make a drastic change to the look of your vehicle. there are pics in my gallery (i think there are some before and afters)
Old Dec 31, 2008 | 08:09 AM
mjunk1's Avatar
mjunk1
I've used the pads you get at autozone with varying degrees of success. First time I didn't read the directions and just slapped one on my drill and went to polishing. Turns out you are supposed to spray a little water on them ........... well, I wasted about 4 pads before I finally smartened up and read. Little white powder flakes blowin all over the place!!!
Once I used them correctly it was decent, but I'm sure you can do better with a better system.
One lesson I have learned on polishing things, take your time and expect it to take a good bit of time. I did my forks on my HD and started with 300 grit, then 600, then 1000, etc. Wet sanded everything and really worked hard. My hands were wicked sore the next day. But it came out like new. Same applies here. If you use the Mothers as suggested and really take your time it should polish up nicely.
Old Dec 31, 2008 | 08:55 AM
steve(ill)'s Avatar
steve(ill)
Old Dec 31, 2008 | 09:02 AM
Bobby82490's Avatar
Bobby82490
X2^. I bought my lightning style lights for like $110 shipped to my house and they made a big difference in light output.
Old Jan 1, 2009 | 02:32 AM
projectbad78's Avatar
projectbad78
you can also try rubbing compound
Old Jan 3, 2009 | 04:56 PM
TheProfessorofTOOL's Avatar
TheProfessorofTOOL
You could also try using regular toothpaste and a cloth
Old Jan 3, 2009 | 05:19 PM
HomerWinzlow's Avatar
HomerWinzlow
30.00 shipped for new..
eBay Motors: 2000 00 2001 01 Ford F150 Truck Headlight Headlamp LH (item 110332100700 end time Jan-06-09 13:51:27 PST)
Old Jan 3, 2009 | 08:16 PM
lzrj's Avatar
lzrj
I like the look of the clear crystal headlights like most vehicles use today. You can get the headlights and corner for $100 or less. I don't like the funky future looking headlights that the younger crowd uses. But I like to keep mine as close to factory looking as possible. Do too much and it looks too godly. I agree with just using a polishing compound and elbow grease for the cheapest fix. Never pay someone for work you can do yourself unless you just have money to throw away.
Old Jan 4, 2009 | 06:51 AM
Ron W.'s Avatar
Ron W.
3M number 39017 works well for "yellowed" lens's and cost a lot less than $90
