I want to buy Epd444's 4" lift for my rig but since I got a 250 I need the center hinge drop bracket. Problem. I called a few dealers and they are tellin me at least 400 dollars for the bracket itself. At this rate it may pay to either not do the lift or find a cheaper heavy duty bracket. Any help would be appreciated guys. Thanks
From what i've found a 4" skyjacker suspension lift will run upwards of $1,000. I really wanted to go with the 4" lift but i'd just assume save a couple hundred bucks and do 2" suspension and 2" body
I really like TTB front end, but not enough to deal with all the BS just to add a lift kit.
I'd swap in a d60 front or similar with the new springs under there as well.
Jethro, his lift comes with driveshaft's too right?
Dont want you to get this on there, and have them be to short, or you tear a spline cause you didn't have it on the shaft far enough.
Not sure if those are needed, but seem to be to me.
It does not come with drive shafts, I'm just selling the lift no driveshafts.
On my 350 with a 6'' lift I did not need to do a thing to the driveshafts and its been fine.
I have a 4" lift on my F250 plus a add-a-leaf in the front because of the extra weight of the winch, haven't had to do a thing with driveshafts, shimming pinion yoke, etc works great.
thanks for the link but they look to light duty. i think im gonna hold off and be smart and get must haves firt like guages. i need them bad cause i dont know what my engine is doin with these mods. sorry i wasnt on i was out cruisin with my new down pipe = )
