Cold start stall fix
Old Dec 30, 2008 | 10:09 AM
MagKarl's Avatar
MagKarl
Thumbs up Cold start stall fix
Our 01 V10 Ex developed a cold start stalling problem where the rig cranked and lit fine, but would immediatly stall unless you got on the gas and held the idle up till it warmed up. Searching here led me to the Idle Air Control valve. Evidently it is quite common for the IAC to get carboned up on the Triton engine family. I pulled the valve and cleaned it with throttle body cleaner and q-tips, probably a 20 minute job start to finish. Since then we've had zero cold start issues, it appears to have solved the problem. Thanks to all those who have discussed these type of issues here for others to learn from.
Old Dec 30, 2008 | 01:00 PM
Monsta's Avatar
Monsta
Sit. Stay.
Cool! Glad you're back to 100% driveability!
Never had the issue on either V10 but look forward to the problem because it's such a simple fix.
Jlckb5
Nov 7, 2011 07:50 AM
LI250
Oct 15, 2011 05:33 PM
wasa 1500
13
Feb 2, 2009 08:39 AM
jason86
1978 - 1996 Big Bronco
Feb 11, 2002 01:47 PM
