Sponsored by: Real Truck
Leveling Kit Issues!!!!
Old Dec 30, 2008 | 09:53 AM
budcocustom's Avatar
budcocustom
I have a 02 F350 Crew cab LB 7.3PSD and i but a leveling kit on it about 14 mounths ago. I used the new spring packs instead of the hangers so i could put the factory springs on my off road truck. to make a long story short about a week ago i found out that i had broak a leaf on the leveling kit on my 02. when i dropped the axle i found that on the LF side had 3 broken leafs and the RF had 2. of couse i am at 14 mounths and they will not warrenty anything. this truck has about 12k miles on the lift and were mostly highway. i use this truck to hall my equipment to a job site and long distance travel. What i am looking for is any suggestions on a kit that is a little more reliable. i will not give the name of the kit that i have not because that is not what i am here to do. i just need my truck back on the road.
Thanks in advance
Buddy Lee
P.S. the factory ones i put under my other truck haven't broke and in the last 5k miles about 50 miles were highway. the rest were off not that that matters.
Old Jan 4, 2009 | 12:43 AM
Steve_250's Avatar
Steve_250
What were you doing when it broke?
Old Jan 4, 2009 | 12:46 AM
sarnott140's Avatar
sarnott140
doesn't matter, springs shouldn't break that quick that easy
Old Jan 4, 2009 | 01:03 AM
Steve_250's Avatar
Steve_250
Well gee, gosh, I guess if he were jumping the truck they would still be ok....
Don't you get it? It was a bump for this guy's post!
Old Jan 4, 2009 | 01:16 AM
dew the thunder's Avatar
dew the thunder
What brand springs did you buy? I think I read about Rough Country springs breaking before...
Old Jan 4, 2009 | 09:52 AM
suzuki0702's Avatar
suzuki0702
im running the superlift springs from summit with a 900lb plow on the front. barely sags with that so i guess your heavy diesel engine would be similar. im happy with them and the price was right. 134 a side.
Old Jan 5, 2009 | 07:55 PM
Flatdeck's Avatar
Flatdeck
Here's a suggestion:
Buy X-code front springs. Cut your old leaves to make a 2"-thick zero-rate spring pack. Pick up a set of center-bolts and bolt the zero-rate packs to your X-code springs.
I just did this, but with V-code springs as I got a super deal on them.
Use new U-bolts of course.
Old Jan 6, 2009 | 07:42 AM
budcocustom
Thanks Guys, i like the spec on superlift and will give them a try.the springs i had were Rough Country. i guess live and learn
To answer the question my truck was sitting in the driveway when part of the bottom leaf fell off. I saw it laying by the tire. after i jacked the truck up and removed the U-bolts is when the rest fell off. most of them broke at the center bolt.
TritonF150
Aug 23, 2011 07:49 PM
Rcontrollers
Feb 8, 2011 03:25 PM
geraldo14
Mar 3, 2008 07:39 PM
maevans
23
Jan 18, 2006 07:11 AM
