Sponsored by: Real Truck
Super Duty Leveling Kit
Old Aug 23, 2011 | 07:08 PM
TritonF150's Avatar
TritonF150
Hello all, i have a 2000 F-250 5.4 4WD super duty and had found some springs to put on it, to replace the sagging old ones. The new used one's i bought are off a 2000 and are the plow prep/heavy service springs as apposed to my reg leafs, anyway i also have a 2" leveing kit i am to put on it with those springs and all together it should be around 3" of front lift. My question is besides new I bolts and u-bolts do i also need a drop pitman arm on the truck? Thank you all and i am sorry about writing a novel, god bless
Old Aug 23, 2011 | 07:39 PM
BigPigDaddy's Avatar
BigPigDaddy
No, you don't need a drop pitman arm. I did the exact same thing, installed V code springs of a diesel and the mini-spring pack. That gave me about 2.75" of lift in front. The only thing you might consider is an adjustable track bar to keep your axle centered. My axle is about 3/4" to one side. Not enough to concern me. Maybe when I have some extra $ I will get this one as it is the best price around and has great reviews from others here on FTE.
I also went to a 4" block in back and it sits perfect!
Before:
After:
Old Aug 23, 2011 | 07:49 PM
TritonF150's Avatar
TritonF150
great news thanks alot for your help! i apppreciate it, the guy i bought them said i might need one but i will keep the track bar in mind
rickdavis81
Apr 10, 2014 06:59 PM
Iallwork
53
Apr 23, 2012 09:38 PM
billhoag
Oct 28, 2009 06:31 PM
yachtonwheels
Jun 1, 2009 08:53 PM
CobraGT40
Aug 15, 2006 12:14 AM
