Ultimate tie rod replacement
Old Dec 29, 2008 | 09:44 PM
CanadianSmokie's Avatar
CanadianSmokie
Just thought I would pass on this setup of replacing the weak, low slung, tie rods and drag links we have on our SD's.
Genuine Bullet Proof Steering Systems, Track Bar Kits, Pitman & Steering Arms
The site isn't the best designed for navigating but if you take the time to read through, you'll realize this system is by far the best steering replacement out there. I will be ordering a set in the new year and will do a review when installed.
Old Dec 29, 2008 | 11:37 PM
ReAX's Avatar
ReAX
I wouldn't mind having the bar connecting the pitman arm and steering knuckle near parallel. It should tighten the steering up a bit and make more use of the power from the power steering system. Not a bad price either, $385 for the basic system plus over the knuckle. Stock replacement parts aren't much less.
Old Dec 30, 2008 | 08:35 AM
CanadianSmokie
Thats what I was thinking... why replace with stock when you could put this bad boy on and never have to worry about it again.
Old Dec 30, 2008 | 02:48 PM
ReAX's Avatar
ReAX
The heim joints will fail with time, it's not going to last forever. However, they will hold up extremely well and offer some flexibility.
Old Nov 7, 2011 | 12:11 PM
ATG_Tuning's Avatar
ATG_Tuning
old thread brought back...
I recently picked up a 2003 V10 excursion Limited (high miles but got for a steal). One of my tie rod ends def needs to be replaced, but whenever possible i like to replace stuff with something better than was originally there.
Anyone have reviews of the above listed parts or suggestions on other replacement parts? Thinking about changing ball joints out also if anyone has recommendations (hear they are prone to failure).
Thanks everyone
Old Nov 11, 2011 | 04:57 PM
chetspencer's Avatar
chetspencer
Thanks for the link!
Old Nov 12, 2011 | 10:42 AM
wallz's Avatar
wallz
Thanks everyone
I recently replaced ball joints with XRF. Good reviews on them and they are doing well. Ordered cheapest off eBay.
You might want to check out Dana trac web site also.
Old Jan 18, 2014 | 09:35 PM
00N8's Avatar
00N8
I'm digging up old tie rod threads to see if anyone actually tried these guys, seems like Moog, XRF and local parts store tie rods and tie ends only last a couple years with hard use.
Anyone try Bulletproof Steering?
Old Jan 19, 2014 | 08:14 AM
phnguyk's Avatar
phnguyk
I used them on my '72 Bronco, absolutely best upgrade ever. Knuckle over, the heim joints were beefy and held up awesome.
Old Jan 19, 2014 | 11:33 AM
EXv10's Avatar
EXv10
Because you probably won't have the truck that long.
Old Jan 19, 2014 | 11:56 AM
Magnus E's Avatar
Magnus E
Since the Excursion is the last of a breed, for those that need or fancy themselves in this type of vehicle long term quality investments make sense.
Old Jan 19, 2014 | 03:48 PM
EXv10's Avatar
EXv10
But things pop up and people sell or a lot can happen to a vehicle. That's why you don't see tons of 70's cars running around.
Old Jan 19, 2014 | 04:13 PM
bonedoctor's Avatar
bonedoctor
I rebuilt my entire front end with XRF parts. Ball joints, tie rods and ends, and draglink. Has held up great and carries a million mile warranty.
Old Jan 19, 2014 | 04:46 PM
mecdac's Avatar
mecdac
Exclamation Figure of speech, I am sure
Uh, tons come on you can do better than that.
Old Jan 19, 2014 | 08:27 PM
WE3ZS's Avatar
WE3ZS
Canadiansmokie hasn't posted in a little over a year but I believe that his EX is Line-Xed, there has been some conversations about that particular way to ruin, oops, I mean mod an EX here lately.
rigsboo
Mar 6, 2017 12:05 AM
treverd
Jan 16, 2017 02:28 PM
AKHunter93
21
Aug 19, 2016 01:10 AM
f150crewcab
Jul 8, 2014 07:49 PM
dacriss
Oct 29, 2009 05:51 AM
