where can i get......?
do you have a link or anything to those bigblockford?
i havnt made it to the junk yard but i got good leaf springs from a friend as mine are broke im going with a bigger block in the back [4inch will lift it 2 from stock] and coil in the front
jus to make sure the 33 12.5s i am getting this spring will clean no prob
thanks again
thanks again
The blocks that I got I actually purchased from a local 4x4 dealer. But here is a set from summit racing that even comes with new u-bolts and hardware which you would need to replace anyway.
Superlift Suspension 1049 - Superlift Rear Block Kits - summitracing.com
mtgrzlyman
37
07-17-2005 08:48 PM
