Sponsored by: Kumho
engine swap
Old Nov 23, 2000 | 12:41 AM
blacksheep30534's Avatar
blacksheep30534
engine swap
Ive got a 83 f100 2wd with I6 and aod, Id like to go with a 351w,c6 or 460,c6. I need to know how much each engine weighs
before I order the front suspension, so if anyone can help
Id appreciate it.
Old Nov 23, 2000 | 08:04 AM
billyb's Avatar
billyb
engine swap
unless your going to the 460, don't worry about the weight.
by the way, why are you changing from the i6?
Old Nov 23, 2000 | 09:57 AM
StrangeRanger's Avatar
StrangeRanger
engine swap
From what I've read, the 351 weighs roughly 100# more than the 300, I 've never weighed them so I don't know for sure. Don't know about the 460.
Old Nov 24, 2000 | 11:23 AM
blacksheep30534
engine swap
Thanks for the reply, The thing is that Ive got access to a 460.
but Im afraid that there will be too much to modify. I believe
a 351w could bolt in with a radiator and a transmission.I was wondering about the weight because Im putting a heidts front suspension under the front. Its going to be a project truck so the first thing to go is the I6. thanks again blacksheep
Old Nov 24, 2000 | 08:46 PM
billyb's Avatar
billyb
engine swap
the460 weighs about 700 lbs. you can trim weight by using aluminum intake and heads, but it is a big motor.
the i6 is around 400 lb. the 351 about 480-500.
as for difficulty in putting 460 in truck, it does require parts, but they are available from L+L in texas, or from recycler of of factory trucks.
it gives a heck of a kick to an f150!
Old Nov 25, 2000 | 11:26 AM
blacksheep30534
engine swap
Do you know the horsepower between the two? I imagine there is
quite a difference in price to build them. I only have about $2000 to spend on the engine.
Old Nov 25, 2000 | 05:40 PM
billyb's Avatar
billyb
engine swap
you don't have to build the 460!! just put it in and enjoy a reliable stock high power engine.
the engine was used in lincolns as well as trucks, and it ran nice and smooth, but when the lincoln owner had his wife and friends in the big car, it would get out of its own way real quick.
it is a brute , but a gentleman in one package!
Old Nov 26, 2000 | 09:34 AM
DannyP's Avatar
DannyP
engine swap
I know where a 69 Lincoln Conty is with what I assume is the original 460. I drove it but I couldn't cut her loose because the owner was with me. He wants to sell it, and I'd like to have it, but I am reluctant to spend any more bucks on vehicles/parts right now. My wife has been very understanding so far but I don't want to push my luck. I do wish I had known of this before I built my 351W tho.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Nov 27, 2000 | 04:56 PM
proeliator's Avatar
proeliator
engine swap
