Oasis Help understanding????
Old Dec 29, 2008 | 01:05 AM
JHB's Avatar
JHB
Can someone please tell me what all this means? Good/Bad? Run fast? Is the truck good to go now? Sorry I have no idea about this stuff..... Thanks
The Oasis report is copy righted material, you may discuss the report, Thanks MAX
Old Dec 29, 2008 | 08:23 AM
powerstroke72's Avatar
powerstroke72
Everything except the last entry is trivial. The last entry is regarding the all too common head gasket failure. To be honest though, I really don't think I'd worry too much about that. The necessary repairs were made and from the looks of it, they were done by a competent tech who didn't stop at the head gaskets. He saw the need for the replacement short block and performed the swap.
In short, one of the inherent weak links in the 6.0 engine has been fixed on this one. I'd test drive it, check it from front to back for leaks, damage, etc. and go for it if the price is right. The OASIS shows no recurring electrical problems and nothing that would cause me to not buy it.
Also, just FYI and Moderator correct me if I am wrong, you can't post the actual OASIS report as it is copyrighted by Ford. Good luck.
Old Dec 29, 2008 | 08:46 AM
wiingnut's Avatar
wiingnut
Be patient here. First things first! You need to open up your window on your computer all the way and this info will probably make a little more sense. Its just crunched together right now. the info quoted above is your VIN and various codes for the truck, production date, date truck sold(start of warranty), mileage repair made.
Good luck I agree with what powerstroke said in his comments.
Edited by Max
Old Dec 29, 2008 | 01:54 PM
JHB's Avatar
JHB
So can someone tell me what R and R means? And what is the short block? Sorry for the dumb?????????? Thanks
Old Dec 29, 2008 | 02:04 PM
gotfu's Avatar
gotfu
r&r means "remove and replace"
short block is engine minus heads
basically the complete engine has been replaced not just the heads
hope this helps
Old Dec 29, 2008 | 04:44 PM
bpounds's Avatar
bpounds
Anybody care to enlighten us on "installed valve grind kit on both heads"?
Why would two new heads require any grinding?
Old Dec 29, 2008 | 06:10 PM
sideshow's Avatar
sideshow
while we're on the subject......how does this one look. edited cause i couldn't make sense of it. see post below
Old Dec 29, 2008 | 06:11 PM
sideshow's Avatar
sideshow
oops......
Old Dec 29, 2008 | 06:25 PM
bpounds's Avatar
bpounds
That looks like a good history. Most of it is recalls. There was a fuel pressure problem, but the tech didn't say what he did. Then a "modulator" valve was replaced most recently. All minor things.
The very first item is interesting. It was 2 quarts low on oil from the factory. They found it during the PDI, predelivery inspection. It holds 15 quarts, so 2 quarts is no big deal. I just found it interesting.
Old Dec 29, 2008 | 07:15 PM
wiingnut's Avatar
wiingnut
Looks pretty good to me too. All minor stuff. As for the engine being 2 qts. low, their scale must have been off. I know when the trans are loaded onto racks, the transmissions are weighed and that will signify being short on fluid.
superhooperduty
Mar 3, 2014 10:05 PM
scarty111
Sep 1, 2013 12:38 PM
davlan88
Feb 27, 2013 03:24 PM
Big Brute
Nov 8, 2009 08:13 PM
01f350
2004 - 2008 F150
35
May 13, 2008 09:50 AM
