Grease Monkey concerns
Old Dec 27, 2008 | 03:09 PM
datkins587's Avatar
datkins587
I just took my 2004 F350 for an engine oil change and transmission fluid change at Grease Monkey at 30,000 miles.
First concern was they told me that Ford only uses synthetic tranny fluid so it cost $175 to change. Seems high, was it?
Second concern is when I checked the engine oil on dip stick after the oil change it looked really dark (Rotella oil). I even put some on a white napkin and it definately looked very dark grey to black. I asked the guy at Grease Monkey why it was so dark and he says the oil always looks like that in diesels. Sounds like BS to me, was he right?
Did they take my money and leave in the old oil? I spent $280 bucks at that place and that was even after a $6.00 discount coupon!
Old Dec 27, 2008 | 04:38 PM
powerstroke72's Avatar
powerstroke72
My 30k tranny service cost around $135 and change at the dealer. I'd get an oil sample and send it to Blackstone :
Blackstone Laboratories - Diesel Engines
Don't know if it will tell you if it's the same oil or not but is a good analysis. My oil has never been gray to black following a change. Did they change the filter too or just the oil?
Old Dec 27, 2008 | 05:25 PM
ljutic ss's Avatar
ljutic ss
My oil with 2,200 on it is still not black or gray. Rotella synthetic. Sounds like something is not right.
Old Dec 27, 2008 | 07:21 PM
UGA33's Avatar
UGA33
The only fluid for the Torqshift tranny is Mercon Sp and it is a synthetic. I hope this is what they used. It usually runs $6-7 a qt. The oil will look black after a change because when you do an oil change on the 6.0L, usually only 13.5-14 qts drain. The system holds 17 qts, a few quarts of old oil stays in the system giving you the black look right after the change. Drive it to get the old and new oil mixed and it should look fresh. Hope this helps. My dealer charges $205 dollars and that is for a heated flush and 17 quarts and a filter.
Old Dec 27, 2008 | 07:44 PM
datkins587's Avatar
datkins587
Doing a little research on here it sounds like there is an external tranny filter somewhere up by the radiator. These guys said my truck did not have an external filter and say they cleaned the internal one. In order to do that it sounds like you would have to pull the pan. Don't think they could have done all that in the 20 minutes they had it. It did say they used 11 quarts of Mercon SP on my reciept. Serves me right, next time I will do it myself. Then I know what's been done. The thing that concerns me now is I'm about 3 days from leaving on a 5000 plus mile trip pulling a 12000 pound 5th wheel trailer. If they didn't do what they claimed I may be in trouble.
Old Dec 27, 2008 | 09:13 PM
73f100shortbed's Avatar
73f100shortbed
One of the reasons not to go to quick lube places. I know people want stuff done quickly, but these places do it so quick you are left wondering what was really done. I would simply say you have 3 choices of what to do:
1. Hope you got what you paid for and enjoy your trip.
2. Take it to the dealer where it should be done right
3. Do it yourself and know it is done right.
If it does have an external filter change that yourself and add whatever fluid you need to top off trans. Sorry to hear you had an experience that leaves you wondering...
Old Dec 27, 2008 | 09:22 PM
06silvercrew's Avatar
06silvercrew
Well is what it all boils down too is this. Do you really want a person making $6 an hour at a place that has probably a huge turnover working on your $40K truck?
Do it yourself if you feel comfortable, or take it to a dealer that you know and trust...There is plenty of info here on fte to guide you.
Old Dec 27, 2008 | 09:28 PM
powerstroke72
Well said. I hadn't even thought about the quality of workers that are usually at these places but you're exactly right.
Old Dec 27, 2008 | 09:40 PM
conger's Avatar
conger
Get a Fomoto valve for your oil changes and do it yourself. I'd still have the dealer do the hot flush on the trans. Oil changes are very easy on the 6.0, it's your engine's life blood. I wouldn't trust any of those quicky lube places. If they do something to cause engine problems, how much luck do you think you'd have getting them to accept responsibility and paying for repairs?
Old Dec 27, 2008 | 09:45 PM
dschuffert's Avatar
dschuffert
This doesn't sound quite right. After an oil change the oil should not appear black at all. I wonder if they changed the filter or not? Synthetic is correct for this transmission, but it needs to be Mercon SP.
Old Dec 27, 2008 | 10:37 PM
conger's Avatar
conger
A lot of these quick lube places don't use the Motorcraft or Fram filter and opt for the cheaper Wix filter. Does the receipt say what kind of oil filter was used? If it's a Wix unit, they come with their own cap, so they may have garbaged yours. Check to see if the OEM filter cap is still on the engine or if it's the taller Wix unit. If the OEM is gone, make them replace it.
Old Dec 28, 2008 | 04:29 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I'll bet they drained the oil pan, put the drain plug back in, and then replaced the oil filter (if at all). If this was the process they followed, then the one or so quart of dirty oil in the oil filter resevoir drained back into the oil pan when they removed the filter cap. Others are correct in there still being 2 qts of used oil trapped in the high pressure oil system. This might explain your oil being somewhat "dirty" after the change. However, it should still have somewhat of a golden tint to it and shouldn't be completely black.
By the way, the proper process is to loosen the oil filter cap first to allow the oil in the resevoir to drain back down into the pan prior to draining the pan. This insures the used oil in the resevoir gets drained with the other oil that is in the pan.
Old Dec 28, 2008 | 05:22 PM
datkins587's Avatar
datkins587
Just for grins I drove the truck today about 40 miles, to mix up the oil.
I let it sit a couple hours then pulled an oil sample out at the pan drain plug.
I was shocked, it wasn't just grey or dark it's flat out black.
I'm heading back there tommorow to confront them. It's bad enough to pay what these guys charge for a diesel oil change but when they take your money and don't even change it, that's robbery!!
Old Dec 28, 2008 | 07:01 PM
dschuffert's Avatar
dschuffert
I completely agree with you. It sounds like the oil didn't get changed at all. Good luck and keep us posted on happens!
Old Dec 28, 2008 | 09:06 PM
Saleenguy's Avatar
Saleenguy
Did you look at your oil filter immediately after the oil change, to see if it had been replaced with a new one?
