Add-a-leaf
Old Dec 28, 2008 | 08:51 PM
FARM69's Avatar
FARM69
Add-a-leaf
I'm finally going to install the add-a-leafs for my front suspension tomorrow. They have been sitting in my basement for months now. What is involved in this process? I know I will need new u-bolts but that should be it right? I'm also getting new tires tomorrow or Tuesday.
I'm thinking it will only take a couple of hours to do this?
Old Dec 28, 2008 | 08:58 PM
c00nhunterjoe's Avatar
c00nhunterjoe
shouldnt take long at all, you should also have new center pins for the springs that came with the add a leafs.
Old Dec 28, 2008 | 09:15 PM
tjbeggs's Avatar
tjbeggs
You shouldn't need new u-bolts. They should be long enough IIRC. New center bolts as Joe said and an alignment when your done cause your camber and toe in will be way off. be prepared to spend a little extra on the alignment for camber bushings.
Old Dec 28, 2008 | 09:24 PM
FARM69's Avatar
FARM69
Yeah it needs an alignment pretty bad. This might sound like a stupid question but do the helpers go below the existing leafs or above? The curve should point down right? It's been so long since I got them I can't remember how they are supposed to go anymore.
Thanks for the help gentlemen....
Old Dec 28, 2008 | 09:29 PM
c00nhunterjoe
below your existing springs.....make the new spring smile, not frown
Old Dec 28, 2008 | 09:59 PM
FARM69's Avatar
FARM69
I see. I would have thought they would frown for some reason. Aynways thanks for the help Joe. Doesn't sound like it will take me too long.
