Help I'm Lost
Old Dec 28, 2008 | 07:21 PM
cadetcommander20's Avatar
cadetcommander20
Help I'm Lost
I have a 2002 7.3 power stroke new batts , GPR, GPs, Turbo, and service with 15-40 Delo i'm in south Ga so it does not get that cold here but the truck has a hard start problem and smokes bad when it frist fires up and while it idles when i rev up to 1400-1800 smoke goes away the air intack tubes are fuel of oil that is from the air filter back and the turbo tubes are also full of oil thanks for any help guys HPOP is ok also
Old Dec 28, 2008 | 08:19 PM
WMDPSD's Avatar
WMDPSD
I am not sure but sounds like maybe your turbo might of went out.
Old Dec 28, 2008 | 08:20 PM
cadetcommander20
the turbo was rebuilt a little while back
Old Dec 28, 2008 | 08:29 PM
That_Guy's Avatar
That_Guy
The oil in the tubes is normal, Ford vented the crank case into the air intake. I dont know what to tell you about your smoke issues though.
Old Dec 28, 2008 | 08:37 PM
westpsd's Avatar
westpsd
It sounds like you have replaced everything that would normally be suspect, but if you haven't done it yet, make sure that the GPR is actually working. I put a new one on and it lasted less than two weeks. Just verify that both of the big studs have power on them when you first turn on the ignition. It sounds like the GP's are hot heating. Is the smoke white, blue or black? Does the truck smoke any other time other than when first started? The smoke is what makes me think that the GP's are not working.
Old Dec 28, 2008 | 08:43 PM
cadetcommander20
the truck smokes at idle and the GPR is working it is white with a blue tint and smells like fuel and oil
Old Dec 28, 2008 | 08:44 PM
cadetcommander20
how much oil is normal it is like in puddels in the intake tubes
Old Dec 28, 2008 | 08:49 PM
05chop's Avatar
05chop
Did the old turbo fail? Did the mechanic clean up the mess inside the tubes and air to air cooler?
Tenn01PSD350's Avatar
Tenn01PSD350
That is normal for trucks that have never had the CCV mod done and never had the tubes out and cleaned.
Old Dec 28, 2008 | 08:53 PM
Steve_250's Avatar
Steve_250
Um, you already have this topic going...
https://www.ford-trucks.com/forums/8...lp-please.html
It would do you better to keep all the answers in one thread.
No need to double post here, ppl are quick and helpful.
triskit16's Avatar
triskit16
In puddles before or after the turbo?
Old Dec 28, 2008 | 08:54 PM
cadetcommander20
when i replaced the turbo i cleaned the tubes and cooler really well i done the CCV mod but it smoked out the tube really bad and made a miss where ever i parked the truck no the pedistal was bad so i rebuilt the turbo while i had it off
Old Dec 28, 2008 | 08:55 PM
cadetcommander20
both before and after
Old Dec 28, 2008 | 08:59 PM
05chop's Avatar
05chop
Im having a hard time figuring out your WHAT you are saying!
Old Dec 28, 2008 | 09:02 PM
cadetcommander20
oil is puddling before and after the turbo
